๐Ÿค–Have you ever tried Chat.M5Stack.com before asking??๐Ÿ˜Ž
    Turn your M5Stack into a space clock
    5 Posts 3 Posters 9.0k Views
    • pavelprostoP Offline
      pavelprosto
      Turn your M5Stack Core 2 into a space clock
      What can they do:
      • Animated space wallpaper with a flying astronaut
      • Adaptive backlight mode will set the brightness depending on the time of day (Bright screen during the day and dim at night).
      • Add up to 4 alarm clocks. You can set up a repeat by day of the week.
      • Disable and activate alarms using the alarm clock manager.
      • Get notifications from your phone via Bluetooth.
      • Using the settings menu, you can synchronize your watch with the time from the Internet, adjust the brightness of the screen, select an alarm ringtone.
      • Connect to Wi-Fi using Wi-Fi Manager(No need to reboot your device)
      • View the weather using OpenWeather API
      • Run the any *.py scripts from app directory(Calculator, Timer, Weather and etc.).
      • You can enter debug mode directly from the watch menu.
        alt text
      I plan to add:
      • App store. Download applications from the Internet and run them from an SD card.
      • Localization
      You can install this firmware from M5Burner or if you have the current version of UIFlow_Core 2 run the code of the installer from my GitHub (then your existing scripts should be saved)
        Stoni99
        I like it!๐Ÿ‘
          pavelprosto
          Thanks๐Ÿ˜‰
            Kombistack
            Amazing! Thank you very much Pavelprosto.
              pavelprosto
              if you want the same stand as in the photo. This is a free 3d printer model
              https://www.thingiverse.com/thing:4883660
              With your input, this post could be even better ๐Ÿ’—
