<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Turn your M5Stack into a space clock]]></title><description><![CDATA[<p dir="auto">Turn your M5Stack Core 2 into a space clock<br />
<img src="https://github.com/pavelprosto94/space_clock/raw/main/resources/IMG_20220930.jpg" alt="" class=" img-fluid img-markdown" /></p>
<h2>What can they do:</h2>
<li>Animated space wallpaper with a flying astronaut</li>
<li>Adaptive backlight mode will set the brightness depending on the time of day (Bright screen during the day and dim at night).</li>
<li>Add up to 4 alarm clocks. You can set up a repeat by day of the week.</li>
<li>Disable and activate alarms using the alarm clock manager.</li>
<li>Get notifications from your phone via Bluetooth.</li>
<li>Using the settings menu, you can synchronize your watch with the time from the Internet, adjust the brightness of the screen, select an alarm ringtone.</li>
<li>Connect to Wi-Fi using Wi-Fi Manager(No need to reboot your device)</li>
<li>View the weather using OpenWeather API</li>
<li>Run the any *.py scripts from app directory(Calculator, Timer, Weather and etc.).</li>
<li>You can enter debug mode directly from the watch menu.<br />
<img src="https://github.com/pavelprosto94/space_clock/raw/main/resources/help.jpg" alt="alt text" class=" img-fluid img-markdown" /></li>
<h2>I plan to add:</h2>
<li>App store. Download applications from the Internet and run them from an SD card.</li>
<li>Localization</li>
<p dir="auto">You can install this firmware from <strong>M5Burner</strong> or if you have the current version of <strong>UIFlow_Core 2</strong> run the code of the installer from my <a href="https://github.com/pavelprosto94/space_clock#installation" target="_blank" rel="noopener noreferrer nofollow ugc">GitHub</a> (then your existing scripts should be saved)</p>
]]></description><link>https://community.m5stack.com/topic/4720/turn-your-m5stack-into-a-space-clock</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 03:18:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4720.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 16 Oct 2022 19:58:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Turn your M5Stack into a space clock on Mon, 17 Oct 2022 12:09:46 GMT]]></title><description><![CDATA[<p dir="auto">if you want the same stand as in the photo. This is a free 3d printer model<br />
<a href="https://www.thingiverse.com/thing:4883660" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.thingiverse.com/thing:4883660</a></p>
]]></description><link>https://community.m5stack.com/post/19012</link><guid isPermaLink="true">https://community.m5stack.com/post/19012</guid><dc:creator><![CDATA[pavelprosto]]></dc:creator><pubDate>Mon, 17 Oct 2022 12:09:46 GMT</pubDate></item><item><title><![CDATA[Reply to Turn your M5Stack into a space clock on Mon, 17 Oct 2022 11:51:11 GMT]]></title><description><![CDATA[<p dir="auto">Amazing! Thank you very much Pavelprosto.</p>
]]></description><link>https://community.m5stack.com/post/19011</link><guid isPermaLink="true">https://community.m5stack.com/post/19011</guid><dc:creator><![CDATA[Kombistack]]></dc:creator><pubDate>Mon, 17 Oct 2022 11:51:11 GMT</pubDate></item><item><title><![CDATA[Reply to Turn your M5Stack into a space clock on Mon, 17 Oct 2022 08:26:33 GMT]]></title><description><![CDATA[<p dir="auto">Thanks😉</p>
]]></description><link>https://community.m5stack.com/post/19007</link><guid isPermaLink="true">https://community.m5stack.com/post/19007</guid><dc:creator><![CDATA[pavelprosto]]></dc:creator><pubDate>Mon, 17 Oct 2022 08:26:33 GMT</pubDate></item><item><title><![CDATA[Reply to Turn your M5Stack into a space clock on Mon, 17 Oct 2022 05:02:57 GMT]]></title><description><![CDATA[<p dir="auto">I like it!👍</p>
]]></description><link>https://community.m5stack.com/post/19002</link><guid isPermaLink="true">https://community.m5stack.com/post/19002</guid><dc:creator><![CDATA[Stoni99]]></dc:creator><pubDate>Mon, 17 Oct 2022 05:02:57 GMT</pubDate></item></channel></rss>
