    new m5stack: Failed to write to target RAM (result was 01070000)
    Bug Report
    13
    22
    68.2k
    • E
      erich
      This was a known issue with Big Sur (something related to the python and / or serial port implementation in Big Sur.
      I did contact M5Stack support but no solution has ever been found.
      I gave up and reverted back to Catalina and it worked fine again.
      Now I just installed the latest Monterey but haven't tested the Core2 yet.
      In the meantime I was also using a windows computer....
        Mackone @erich
        @erich I'm on Mojave 10.14 and problem still exists :/
          I’m actually getting it with Catalina
            slugs
            Has anyone managed to get the core 2 to work with an M1 mac? I think that you do not need the driver for the m1? With a m5stick C it works fine, but not with the core 2
            • ExieE
              Exie
              I have the same issue when I use the M5Stack ESP32 Downloader.
              However when I use a simple M5Stack Atom Matrix, its works fine.
              I am on OSX Big Sir.
              I feel like the issue is related to the CH9102 chip on the ESP32 Downloader where the Atom has the CP2104 I think.
              This theory is supported by this article here:
              https://blog.squix.org/2021/08/ch9102-driver-issues-failed-to-write-to-target-ram.html
              Confirmed, installing the driver from this thread here worked for me
              https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139
              • E
                erich @Exie
                @exie said in new m5stack: Failed to write to target RAM (result was 01070000):
                I guess you're right as I noticed on banggood/ aliexpress some products using this CH9102 chip are tagged as not Mac compatible.
                • L
                  labixiaoxin8888 @Mackone
                  @mackone try connecting the downloader's 3V3 to Stamp Pico's 5V
                  • P
                    parahooner
                    I found a solution that works on Montery :-)
                    Make sure you follow the PDF instructions, this works M1 Mac M5 Epaper
                    http://www.wch.cn/downloads/CH34XSER_MAC_ZIP.html
                    B 1 Reply Last reply Reply Quote 2
                    • B
                      Bludotz @parahooner
                      @parahooner Very many thanks for posting this, it completely resolved the problem.
                      • drjakobD
                        drjakob
                        I still have the same problem with 5 new M5Fire on Big Sur. Two older ones burned succesful.
                          ajb2k3 @drjakob
                          @drjakob Check which USB driver is in the new cores as the driver chip was changed due to the part shortage.
