    M5Fire and MLX90640 works
    PROJECTS
    20.1k
    • SkinkS
      Skink
      Since the MLX 90640 module is also available from M5Stack, the following software also runs with the MLX 90640 thermal camera.
      Here is the link to the software: https: //github.com/m5stack/M5Stack/tree/master/examples/Modules
      I have just tested it with a M5Stack Fire with 32GB SD card
      • SkinkS
        Skink @Skink
        @skink 在 M5Fire and MLX90640 works 中说:
        • SkinkS
          Skink
          I just tested it successfully with M5Stack Basic.
          • L
            LastCaress
            I've tried it with the fire as well and for me it doesn't work :\ Nothing works with m5stack
            • L
              LastCaress @LastCaress
              @lastcaress 在 M5Fire and MLX90640 works 中说:
              Tried it also on a m5stack core, and ... nothing!
              • SkinkS
                Skink
                @LastCaress,
                maybe you have not installed all the drivers on your Arduino software, work with Arduino 1.8.7 and I work with the sensor as I said with the M5Stack Fire and the M5Stack Basic (black), have attached a few pictures here, no SD card installed nothing, only the port used to the sensor rübergeführt and already the sensor runs on M5Stack!
                Greetings Skink0_1540267642120_DSC_0784.JPG 0_1540267659430_DSC_0785.JPG 0_1540267678083_DSC_0786.JPG 0_1540267694657_DSC_0787.JPG 0_1540267711426_DSC_0788.JPG 0_1540267746544_DSC_0789.JPG
                • SkinkS
                  Skink
                  The red is the battery unit
                  Greetings Skink
                  • L
                    LastCaress
                    The code was compiling, it just didn't do anything when I connected the camera. Tried m5 core, fire and nothing. Tried today with m5go and it worked!
                    alt text
                    I think i have too many m5stack things
                    • SkinkS
                      Skink
                      @LastCaress
                      with me it looks almost exactly as in your picture under your profile on the workplace (Unfortunately, I do not have so many sensors).
                      What I noticed, however, was that I had the IR remote sensor from the M5Go package and it did not work on the M5Go (wise M5Stack) either, because the port (B) seems to be defective because it worked on the M5 Fire. Have then sent the part complete with sensors !!
                      Because software was the same installed on both, on the M5Stack Fire one saw with the mobile phone that the IR sensor sends when connecting to the M5Go where the sensor was received, the IR sensor did not send !!
                      Do not check that the M5Stack is not working because of the warranty
                      Greetings Skink
                        ajb2k3 @LastCaress
                        alt text
                        thats quite a collection you have there.
