    UHF RFID Unit (JRD4035) on M5Core2
    Core 2
    m5core2 uhf examples help rfid
    9
    14.2k
    • T
      tobias.h
      I was wondering if the examples from the M5Stack Repository will be re-released on the M5Core2 repository. Unfortunately I am not able to get my JRD4035 running on a M5Core2. Anybody maybe has experience in this or info when examples will be released?
      Best wishes
      Tobias H.
      Bat21B 1 Reply Last reply Reply Quote 0
        Hello @tobias-h
        you could try to modify the M5Stack example yourself.
        Replace below line:
        #include <M5Stack.h>
        with
        #include <M5Core2.h>
        and below line:
        Serial2.begin(115200, SERIAL_8N1, 16, 17);//16.17
        with this line if you connect the unit to port A (found on M5Core2):
        Serial2.begin(115200, SERIAL_8N1, 33, 32);
        or this line if you connect the unit to port C (found on M5GO Battery Bottom2):
        Serial2.begin(115200, SERIAL_8N1, 13, 14);
        • T
          tobias.h @felmue
          @felmue thank you very much. it finally works now.
            Hello @tobias-h
            glad to hear it works now. Thank you for reporting back. Have fun!
            • Bat21B
              Bat21 @tobias.h
              @tobias-h said in UHF RFID Unit (JRD4035) on M5Core2:
              Best wishes
              Tobias H.
              What examples is using, I can't make any.
              Thank you.
              • K
                kylebuttress
                @Bat21
                Not sure if this will help.
                I made a quick reader based on a [project I'm working on this also works on m5Paper as well it's nothing complex simple read and display, this is on a Basic Core unit
                A quick video showing it working
                https://youtu.be/qvtr6Vy-HwY
                The Tags I use are these ones
                Tag 1
                Tag 2
                make sure the port is correct otherwise the bytes out of range error pops up
                I hope it helps
                from m5stack import *
                from m5ui import *
                from uiflow import *
                import unit
                setScreenColor(0x222222)
                uhf_rfid_0 = unit.get(unit.UHF_RFID, unit.PORTA)
                uhf_rfid_0.set_region(uhf_rfid_0.REGIN_US)
                uhf_rfid_0.automatic_freq_hopping(0xFF)
                uhf_rfid_0.set_channel_freq(924.25)
                epc_bool = 0
                uhf_rfid_0.set_select_mode(0x01)
                label0 = M5TextBox(128, 59, "Tag #", lcd.FONT_Default, 0xFFFFFF, rotate=0)
                label1 = M5TextBox(22, 106, "waiting ... ", lcd.FONT_Default, 0xFFFFFF, rotate=0)
                while True:
                        # while not temp:
                        temp = uhf_rfid_0.single_polling()
                        if temp:
                            # label10.setText(str(temp))
                            print("-----")
                            print(temp[0])
                            print(temp[1])
                            print("-----")
                            label1.setText(temp[0])
                        wait(.5)
                • Bat21B
                  Bat21
                  @kylebuttress Hello,
                  Thanks for your example, installed vScode IDE with python and program your example.
                  It works the same as in Fixow and Arduino. It only shows 6 EPC characters and only reads some EPCs.
                  It is very strange that with all the examples on different platforms the same thing happens.
                  Thanks for your help,
                  • Bat21B
                    Bat21
                    @kylebuttress
                    Hello again,
                    This is the information that I visualize from the EPC.
                    [From M5Burner] Com22 Opened.
                    30395D
                    -30
                    On the Core 2 screen, it is 30395d.
                    When the complete EPC of the label is 30395DFA835F7E4000466D16
                    I don't understand anything, both in the Core2 and at the Atom.
                    Cheers
                    • Bat21B
                      Bat21 @Bat21
                      Hello everyone
                      Nobody with M5Core 2 and UHF RFID UNIT (JRD4035) running properly?
                      Cheers.
