    UIFlow 1.8.6
    Official Updates
    7
    12
    17.5k
    • m5stackM
      v1.8.6
      new features
      • 1: Add UNIT LCD support.
      • 2: Add UNIT ID support.
      • P
        plusulli
        I would be happy if someone could explain to me how this would work with REMOTE+ and chart data either I do not get it or it does not work
        • m5stackM
          we will update the tutorial as soon as possible
          MatiM 1 Reply Last reply Reply Quote 0
            I2C bus error when trying to use the Colour LCD unit on core 2
            • MatiM
              Mati
              LCD color vs Atom lite
              File "flow/m5cloud.py", line 82, in _exec_fun
              File "<string>", line 20, in <module>
              File "units/_lcd.py", line 128, in fill
              AttributeError: 'Lcd' object has no attribute 'frame_buf'
              File "<string>", line 22, in <module>
              File "units/_lcd.py", line 169, in show_on
              File "i2c_bus.py", line 101, in write_mem_list
              MemoryError: memory allocation failed, allocating 64800 bytes
              • MatiM
                Mati @m5stack
                @m5stack said in UIFlow 1.8.6:
                in my case all is working fine on core2 LCD module is connected over PortA
                  ajb2k3 @Mati
                  @mati said in UIFlow 1.8.6:
                  Have you updated the firmware on the colour lcd?
                  I get the framebuf error if I don't add the init screen block
                  • MatiM
                    Mati @ajb2k3
                    @ajb2k3 said in UIFlow 1.8.6:
                    Nope, just out of the box and go. First try with Atom lite fail but on core2 and init in the setup all looks legit.
                    PhuturistP 1 Reply Last reply Reply Quote 0
                      Soong
                      LCD firmware update and device tested with M5StickC, ATOM, Stamp... From Arduino it works fine but from UIFlow no way.
                      Error from M5StickC plus is "LCD object has no attribute frame_buf
                      • PhuturistP
                        Phuturist @Mati
                        Could you post your working UIFlow?
                        I have the same issue, gives me the error "'Lcd' object has no attribute 'frame_buf'".
                          Hello @Phuturist
                          using UIFlow 1.9.0 works for me (well kind of). With M5Core2 I can use the whole LCD unit screen (eg. 135 x 240). However with M5Atom (or M5StickCPlus) I can only use part of it, else there is an out of memory error. Here is what works for me with M5Atom.
                          • PhuturistP
                            Phuturist @felmue
                            @felmue said in UIFlow 1.8.6:
                            Hello @Phuturist
                            Thanx Felix, it's indeed now working for a small partion of the screen when connected to my M5StickC Plus. Trying to set it to it's actual size indeed results in a memory allocation error. I had seen that one before as well but didnt think it was related to the screen size. If anyone knows how to fix the memory allocation error, please let me know.
