    I2C Error 19
    UIFlow
    5.3k
    • F
      Flow
      i have an M5Stack Core 2 with ENVII sensor (Temperature and Humidity). I have not managed to get it to function using Blockly. Error message I2C bus error 19.
      Running 1.85 version with UI Flow 1.7.5.
      Any help would be appreciated.
      • m5stackM
        could you paste your program screenshot here?
        • F
          Flow
          Simple code to test ENVII - I get two possible results
          1. white screen with nothing on it
          or
          1. I2C BUS ERROR 19
          Code
          from m5stack import *
          from m5stack_ui import *
          from uiflow import *
          import time
          import unit
          screen = M5Screen()
          screen.clean_screen()
          screen.set_screen_bg_color(0xd37272)
          env20 = unit.get(unit.ENV2, unit.PORTA)
          label0 = M5Label('Temperature', x=22, y=45, color=0x000, font=FONT_MONT_24, parent=None)
          screen.set_screen_bg_color(0xffff66)
          while True:
          label0.set_text(str(env20.temperature))
          wait(10)
          wait(3)
          wait_ms(2)
          • F
            Flow
            I have found that connecting the ENVIRO module to the Core 2 causes the M5 to lock up. White screen and nothing else.
            Is the issue with the module or software? Is there a Driver issue?
