    SX1509 library needed.
    SOFTWARE
    10.0k
      meirmark
      Hi.
      I am looking for a library for the SX1509 16 bit I/O extender.
      I will be glad if someone can share.
      Meir.
      • A
        AgreeDK @meirmark
        @meirmark Google is your friend, 1st hit:https://github.com/sparkfun/SparkFun_SX1509_Arduino_Library
          meirmark
          Thanks, Google is My almost the bast friend :-)
          I am looking for a lib for M5Stack and not Arduino, the Arduino lib is not working.
          • A
            AgreeDK @meirmark
            @meirmark I code All my M5Stack pruduct using Arduino ide with added M5 support, so the library work for me.
              meirmark @AgreeDK
              @agreedk I am also using Arduino ide and not all arduino libraries works with M5stack without changes .
              Did You checked the SX1509 specific library or you meant in general that Arduino libraries supposed work with M5stack ?
              • A
                AgreeDK @meirmark
                @meirmark the answer is both, just checked the library it use Wire.h so you only have to use the correct pins in the setup Calle.
