    Typ B (black connection) Units,not working with core2
    units core2
    2 Posts 2 Posters 4.3k Views
    • G Offline
      ganeyvim
      Please advise me on this.
      I have a core2 which I use with the UI flow
      All my type A (red) units (heart, env, air quality), are fine
      The port B type (black) units (rf, buttons, rgb, ir)connect, but are not read.
      What are my options?
        Port A units are digital/i2c and so will work as you have noticed.
        PortB units are analogue devices.
        You can try a PortBHub which will convert analogue to digital or you can try the GoPlus2 module which has analogue pins.
        Alternatively, on the base plate of the Core2 remove the expansion module and you will have access to the MBus connectors with analogue pins.
