[SOLVED] ATOM LITE + OLED Unit 1.3" 128 × 64 Display
Hi all, I'm looking for a working arduino code for ATOM LITE + OLED Unit 1.3" 128 × 64 Display to work with......
best regards
nobody??
just use the M5GFX library.
the library examples doesn't work for me
I tryed with core gray, core2, atom lite without any result...
may be I'm missing something......
some tips???
why is it not working? Any error code? it is difficult to help you if you give no information.
I can upload the exemples sketches but nothing is on the display....
- arduino envirement
 - atom lite
 - oled unit
 - up to date M5GFX
this is a test sketch:
#include <M5GFX.h> M5GFX display; M5Canvas canvas(&display); static constexpr char text0[] = "hello world"; static constexpr char text1[] = "this"; static constexpr char text2[] = "is"; static constexpr char text3[] = "text"; static constexpr char text4[] = "log"; static constexpr char text5[] = "vertical"; static constexpr char text6[] = "scroll"; static constexpr char text7[] = "sample"; static constexpr const char* text[] = { text0, text1, text2, text3, text4, text5, text6, text7 }; void setup(void) { display.begin(); if (display.isEPD()) { display.setEpdMode(epd_mode_t::epd_fastest); display.invertDisplay(true); display.clear(TFT_BLACK); } if (display.width() < display.height()) { display.setRotation(display.getRotation() ^ 1); } canvas.setColorDepth(1); // mono color canvas.createSprite(display.width(), display.height()); canvas.setTextSize((float)canvas.width() / 160); canvas.setTextScroll(true); } void loop(void) { static int count = 0; canvas.printf("%04d:%s\r\n", count, text[count & 7]); canvas.pushSprite(0, 0); ++count; }this is the arduino ide output:
Lo sketch usa 301153 byte (22%) dello spazio disponibile per i programmi. Il massimo è 1310720 byte. Le variabili globali usano 17052 byte (5%) di memoria dinamica, lasciando altri 310628 byte liberi per le variabili locali. Il massimo è 327680 byte. esptool.py v3.0-dev Serial port COM8 Connecting..... Chip is ESP32-PICO-D4 (revision 1) Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse, Coding Scheme None Crystal is 40MHz MAC: d8:a0:1d:5c:95:0c Uploading stub... Running stub... Stub running... Changing baud rate to 1500000 Changed. Configuring flash size... Auto-detected Flash size: 4MB Compressed 8192 bytes to 47... Writing at 0x0000e000... (100 %) Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 4096.1 kbit/s)... Hash of data verified. Compressed 15856 bytes to 10276... Writing at 0x00001000... (100 %) Wrote 15856 bytes (10276 compressed) at 0x00001000 in 0.1 seconds (effective 991.0 kbit/s)... Hash of data verified. Compressed 301264 bytes to 153424... Writing at 0x00010000... (10 %) Writing at 0x00014000... (20 %) Writing at 0x00018000... (30 %) Writing at 0x0001c000... (40 %) Writing at 0x00020000... (50 %) Writing at 0x00024000... (60 %) Writing at 0x00028000... (70 %) Writing at 0x0002c000... (80 %) Writing at 0x00030000... (90 %) Writing at 0x00034000... (100 %) Wrote 301264 bytes (153424 compressed) at 0x00010000 in 2.8 seconds (effective 870.7 kbit/s)... Hash of data verified. Compressed 3072 bytes to 128... Writing at 0x00008000... (100 %) Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 1365.3 kbit/s)... Hash of data verified. Leaving... Hard resetting via RTS pin... Trovata libreria non valida in C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher-master: Nessun header file (.h) trovato in C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher-master Trovata libreria non valida in C:\Users\Documents\Arduino\libraries\URM-master: Nessun header file (.h) trovato in C:\Users\Documents\Arduino\libraries\URM-masterthis is the serial monitor booting the atom lite
ets Jun 8 2016 00:22:57 rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 188777542, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff0018,len:4 load:0x3fff001c,len:1044 load:0x40078000,len:8896 load:0x40080400,len:5816 entry 0x400806ac -
I think I have to change the i2c pin in the library..... but where??
you need to
#include <M5UnitOLED.h>#include <M5UnitOLED.h> M5UnitOLED display; M5Canvas canvas(&display); static constexpr char text[] = "Hello world ! こんにちは世界! this is long long string sample. 寿限無、寿限無、五劫の擦り切れ、海砂利水魚の、水行末・雲来末・風来末、喰う寝る処に住む処、藪ら柑子の藪柑子、パイポ・パイポ・パイポのシューリンガン、シューリンガンのグーリンダイ、グーリンダイのポンポコピーのポンポコナの、長久命の長助"; static constexpr size_t textlen = sizeof(text) / sizeof(text[0]); int textpos = 0; int scrollstep = 2; void setup(void) { display.init(); display.setRotation(2); canvas.setColorDepth(1); // mono color canvas.setFont(&fonts::lgfxJapanMinchoP_32); canvas.setTextWrap(false); canvas.setTextSize(2); canvas.createSprite(display.width() + 64, 72); } void loop(void) { int32_t cursor_x = canvas.getCursorX() - scrollstep; if (cursor_x <= 0) { textpos = 0; cursor_x = display.width(); } canvas.setCursor(cursor_x, 0); canvas.scroll(-scrollstep, 0); while (textpos < textlen && cursor_x <= display.width()) { canvas.print(text[textpos++]); cursor_x = canvas.getCursorX(); } display.waitDisplay(); canvas.pushSprite(&display, 0, (display.height() - canvas.height()) >> 1); } -
@m5stack said in ATOM LITE + OLED Unit 1.3" 128 × 64 Display:
you need to
#include <M5UnitOLED.h>#include <M5UnitOLED.h> M5UnitOLED display; M5Canvas canvas(&display); static constexpr char text[] = "Hello world ! こんにちは世界! this is long long string sample. 寿限無、寿限無、五劫の擦り切れ、海砂利水魚の、水行末・雲来末・風来末、喰う寝る処に住む処、藪ら柑子の藪柑子、パイポ・パイポ・パイポのシューリンガン、シューリンガンのグーリンダイ、グーリンダイのポンポコピーのポンポコナの、長久命の長助"; static constexpr size_t textlen = sizeof(text) / sizeof(text[0]); int textpos = 0; int scrollstep = 2; void setup(void) { display.init(); display.setRotation(2); canvas.setColorDepth(1); // mono color canvas.setFont(&fonts::lgfxJapanMinchoP_32); canvas.setTextWrap(false); canvas.setTextSize(2); canvas.createSprite(display.width() + 64, 72); } void loop(void) { int32_t cursor_x = canvas.getCursorX() - scrollstep; if (cursor_x <= 0) { textpos = 0; cursor_x = display.width(); } canvas.setCursor(cursor_x, 0); canvas.scroll(-scrollstep, 0); while (textpos < textlen && cursor_x <= display.width()) { canvas.print(text[textpos++]); cursor_x = canvas.getCursorX(); } display.waitDisplay(); canvas.pushSprite(&display, 0, (display.height() - canvas.height()) >> 1); }this sketch compile but doesn't display nothing
no error message
this is the atom lite boot on serial monitor after uploaded sketch
@cepics said in ATOM LITE + OLED Unit 1.3" 128 × 64 Display:
I don´t like it ... please remove it and give a try in the loop with a static string ...
And also, put any serial.println() debug code to see what code are you running
@otosan-maker said in ATOM LITE + OLED Unit 1.3" 128 × 64 Display:
...and give a try in the loop with a static string ...
sorry but I don't understand ...
I deleted :
static constexpr const char* text[] = { text0, text1, text2, text3, text4, text5, text6, text7 };this is the compiling error message
Arduino:1.8.13 (Windows 10), Scheda:"M5Stick-C, Default, 1500000, None C:\Users\Documents\Arduino\OLEDDAJE\OLEDDAJE.ino: In function 'void loop()': OLEDDAJE:41:39: error: 'text' was not declared in this scope canvas.printf("%04d:%s\r\n", count, text[count & 7]); ^ Più di una libreria trovata per "SPI.h" Usata: C:\Users\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\1.0.7\libraries\SPI Non usata: C:\Users\Documents\Arduino\libraries\SPI exit status 1 'text' was not declared in this scope Questo report potrebbe essere più ricco di informazioni abilitando l'opzione "Mostra un output dettagliato durante la compilazione" in "File -> Impostazioni -
And also, put any serial.println() debug code to see what code are you running#include <M5UnitOLED.h> //M5UnitOLED display; // default setting M5UnitOLED display ( 21, 22, 400000 ); // SDA, SCL, FREQ -
tnks a lot !!!!
this sketch is working for me#include <M5UnitOLED.h> M5UnitOLED display ( 26, 32, 400000 ); // SDA, SCL, FREQ M5Canvas canvas(&display); static constexpr char text[] = "Hello world ! こんにちは世界! this is long long string sample. 寿限無、寿限無、五劫の擦り切れ、海砂利水魚の、水行末・雲来末・風来末、喰う寝る処に住む処、藪ら柑子の藪柑子、パイポ・パイポ・パイポのシューリンガン、シューリンガンのグーリンダイ、グーリンダイのポンポコピーのポンポコナの、長久命の長助"; static constexpr size_t textlen = sizeof(text) / sizeof(text[0]); int textpos = 0; int scrollstep = 2; void setup(void) { display.begin(); if (display.width() < display.height()) { display.setRotation(display.getRotation() ^ 1); } canvas.setColorDepth(1); // mono color canvas.setFont(&fonts::lgfxJapanMinchoP_32); canvas.setTextWrap(false); canvas.setTextSize(2); canvas.createSprite(display.width() + 64, 72); } void loop(void) { int32_t cursor_x = canvas.getCursorX() - scrollstep; if (cursor_x <= 0) { textpos = 0; cursor_x = display.width(); } canvas.setCursor(cursor_x, 0); canvas.scroll(-scrollstep, 0); while (textpos < textlen && cursor_x <= display.width()) { canvas.print(text[textpos++]); cursor_x = canvas.getCursorX(); } display.waitDisplay(); canvas.pushSprite(&display, 0, (display.height() - canvas.height()) >> 1); }
