    (SOLVED) Help Needed: Keys KY-031 Knock Sensor Module connection to M5Stack Core
    5 Posts 2 Posters 9.0k Views 1 Watching
    • W Offline
      wwhite
      I'm trying to connect this module to my M5Stack Core.
      KY-031 knock sensor module. A vibration sensor that sends a signal when a knock/tap is detected.
      Compatible with Arduino, ESP8266, ESP32, Teensy, Raspberry Pi, and other popular platforms.
      KY-031 Specifications
      This module consists of a 10 kΩ resistor and a spring-based sensor that sends a high signal when a vibration is detected.
      Operating Voltage 3.3V to 5V
      Output Type Digital
      KY-031 Connection Diagram
      Connect the module's Power line (middle) and the ground (-) to +5 and GND respectively. Connect signal (S) to pin 3 on the Arduino.
      KY-031 Arduino
      S Pin 3
      middle +5V
      -GND
      On the Arduino it uses Pin 3. What Pin should I use on the M5Stack?
      Thanks in advance,
      WW
      • world101W Offline
        world101 @wwhite
        @wwhite
        Assuming you have the Core Black or Grey, did you try pin 3?
        https://arduinomodules.info/ky-031-knock-sensor-module/
        • W Offline
          wwhite @world101
          @world101 I just tried pin 3 and didn't have any luck. I'm using a Core Black.
          • world101W Offline
            world101 @wwhite
            @wwhite
            Since it's not an M5Stack product, did you verify it on an Arduino (Uno or other device) to see it working? Also, you might want to post your code to get more assistance.
            That sensor looks like a basic digital low/high sensor. I have never used it, but I have been successful using pin 5 with a different digital sensor. Try pin 5 or pin 2.
            • W Offline
              wwhite @world101
              @world101 So I figured it out:
              On that particular module I connected it as follows:
              Left pin on module labeled 'S' to 5v on the righthand side of M5Stack (red wire)
              Center pin on module (not labeled) to GND on the righthand side of M5Stack (yellow wire)
              Right pin on module labeled '--' to pin 2 on the righthand side of the M5Stack (orange wire)
              After you compile and upload the app tap the module to see the "Tap" message.
