    Works with Chromebook?
    6 Posts 4 Posters 11.5k Views 1 Watching
      chrismoraes
      I'm considering using UIFlow to teach microcontroller programming to high school students. Many of them will be using Chromebooks. Has the browser version of UIFlow been tested with Chromebook OS?
      • B Offline
        BricoMS
        Yes! the browser version of UIflow (web/cloud) does work on my chromebook.
        What you might experience problems is with the m5burner.
        If you have intel based chromebooks you will be able to run it on crostini/linux beta.
        • B Offline
          BricoMS
          And i just tested with the offline UIFLOW Desktp IDE with an intel based Chromebook and it works on linux beta.
          You only need to install libnss3
          • m5stackM Offline
            our engineer is work on the chrome OS compatible problem. so before we fixed it, we still suggest you use win10/MacOS/ubuntu. thank you
              chrismoraes
              Thanks very much! A simple workaround me is to use m5burner on a separate non-chrome machine to load the firmware, and then have the students upload programs via wifi connection. Thanks!
                coffee99 @m5stack
                @m5stack Hey everyone! First post here. Is the full support problem regarding Chrome OS solved? I would like to know if I could flash a M5Stick CPlus on a Chromebook or not. As far as I've read, I can program one via browserbased UIFlow on Chromebooks only...
