    M5Burn cannot set option to USB-mode for local UIFlow-IDE
    Bug Report
    7.4k
    • O
      oklab-ka
      Using M5Burn 1.7.2 (same for 1.7.1) on Linux Fedora 33 with atom-lite or atom-matrix.
      Ich can erase and flash the bootloader. The WiFi dialog on flashing works. But I cannot set config options to USB mode which is needed to use the desktop IDE.
      First, there is a strange message about "setting APN required"
      then javascript error: "loadall is not defined".
      After that, M5burner shows the message "writing data, do not close" but no activity any more.
      How can I set the device to usb mode? Can I do this via esptool.py alone, without the m5burner GUI?
      • world101W
        world101
        This page shows how to put the Atom Matrix/Lite into USB (Desktop) mode.
        https://docs.m5stack.com/#/en/quick_start/atom/atom_quick_start_uiflow
        “Press and hold the middle button while powering on (or when restarting), and do not release it until LED color change to blue.“
        • D
          davelondon @world101
          @world101 I'm having the same problem... this page only seems to give the method of getting the Atom Matrix into offline mode... I have the Atom Lite... I've tried holding the middle button on startup and the LED never goes blue... just green...
            offline mode does not work because the desktop side is out of date.
