    How to install MicroPython libraries? (HTTP GET with query parameters)
    Micropython
    9.0k
      mb
      I would like to do a simple HTTP GET requests with key-value params.
      This seems not supported by urequests, I found a recommended work-around:
      import urequests
      from urllib.parse import urlencode
      def get(url, params=None, **kw):
          if params:
              url = url.rstrip('?') + '?' + urlencode(params, doseq=True)
          return urequests.get(url, **kw)
      payload = {'key1': 'value1', 'key2': ['value2', 'value3']}
      res = get('http://httpbin.org/get', payload)
      print(res.json())
      Sadly urllib.parse from micropython-lib is not included in M5Stack MicroPython.
      How can I install a MicroPython library onto my Core2? I am currently using Thonny IDE.
      • K
        ksprayberry
        See if this helps.
        https://youtu.be/bdyZx2KC54Y
          mb
          Thanks, @ksprayberry, I can manually transfer files. I just thought there was a upip or something on the device which can be used from the REPL.
            mb
            Well, and there is always the option to just strip it down to the basics.
            # urlencode.py
            _ALWAYS_SAFE = frozenset(b'ABCDEFGHIJKLMNOPQRSTUVWXYZ'
                                     b'abcdefghijklmnopqrstuvwxyz'
                                     b'0123456789'
                                     b'_.-')
            _ALWAYS_SAFE_BYTES = bytes(_ALWAYS_SAFE)
            def quote(string, safe='/', encoding=None, errors=None):
                """quote('abc def') -> 'abc%20def'
                Each part of a URL, e.g. the path info, the query, etc., has a
                different set of reserved characters that must be quoted.
                RFC 2396 Uniform Resource Identifiers (URI): Generic Syntax lists
                the following reserved characters.
                reserved    = ";" | "/" | "?" | ":" | "@" | "&" | "=" | "+" |
                Each of these characters is reserved in some component of a URL,
                but not necessarily in all of them.
                By default, the quote function is intended for quoting the path
                section of a URL.  Thus, it will not encode '/'.  This character
                is reserved, but in typical usage the quote function is being
                called on a path where the existing slash characters are used as
                string and safe may be either str or bytes objects. encoding must
                not be specified if string is a str.
                The optional encoding and errors parameters specify how to deal with
                non-ASCII characters, as accepted by the str.encode method.
                By default, encoding='utf-8' (characters are encoded with UTF-8), and
                errors='strict' (unsupported characters raise a UnicodeEncodeError).
                if isinstance(string, str):
                    if not string:
                        return string
                    if encoding is None:
                        encoding = 'utf-8'
                    if errors is None:
                        errors = 'strict'
                    string = string.encode(encoding, errors)
                else:
                    if encoding is not None:
                        raise TypeError("quote() doesn't support 'encoding' for bytes")
                    if errors is not None:
                        raise TypeError("quote() doesn't support 'errors' for bytes")
                return quote_from_bytes(string, safe)
            def quote_plus(string, safe='', encoding=None, errors=None):
                """Like quote(), but also replace ' ' with '+', as required for quoting
                HTML form values. Plus signs in the original string are escaped unless
                they are included in safe. It also does not have safe default to '/'.
                # Check if ' ' in string, where string may either be a str or bytes.  If
                # there are no spaces, the regular quote will produce the right answer.
                if ((isinstance(string, str) and ' ' not in string) or
                    (isinstance(string, bytes) and b' ' not in string)):
                    return quote(string, safe, encoding, errors)
                if isinstance(safe, str):
                    space = ' '
                else:
                    space = b' '
                string = quote(string, safe + space, encoding, errors)
                return string.replace(' ', '+')
            def quote_from_bytes(bs, safe='/'):
                """Like quote(), but accepts a bytes object rather than a str, and does
                not perform string-to-bytes encoding.  It always returns an ASCII string.
                quote_from_bytes(b'abc def\x3f') -> 'abc%20def%3f'
                if not isinstance(bs, (bytes, bytearray)):
                    raise TypeError("quote_from_bytes() expected bytes")
                if not bs:
                    return ''
                    # Normalize 'safe' by converting to bytes and removing non-ASCII chars
                    safe = safe.encode('ascii', 'ignore')
                else:
                    safe = bytes([c for c in safe if c < 128])
                if not bs.rstrip(_ALWAYS_SAFE_BYTES + safe):
                    return bs.decode()
                try:
                    quoter = _safe_quoters[safe]
                except KeyError:
                    _safe_quoters[safe] = quoter = Quoter(safe).__getitem__
                return ''.join([quoter(char) for char in bs])
            def urlencode(query, doseq=False, safe='', encoding=None, errors=None):
                """Encode a dict or sequence of two-element tuples into a URL query string.
                If any values in the query arg are sequences and doseq is true, each
                sequence element is converted to a separate parameter.
                If the query arg is a sequence of two-element tuples, the order of the
                parameters in the output will match the order of parameters in the
                input.
                The components of a query arg may each be either a string or a bytes type.
                When a component is a string, the safe, encoding and error parameters are
                sent to the quote_plus function for encoding.
                if hasattr(query, "items"):
                    query = query.items()
                else:
                    # It's a bother at times that strings and string-like objects are
                    # sequences.
                    try:
                        # non-sequence items should not work with len()
                        # non-empty strings will fail this
                        if len(query) and not isinstance(query[0], tuple):
                            raise TypeError
                        # Zero-length sequences of all types will get here and succeed,
                        # but that's a minor nit.  Since the original implementation
                        # allowed empty dicts that type of behavior probably should be
                        # preserved for consistency
                    except TypeError:
            #            ty, va, tb = sys.exc_info()
                        raise TypeError("not a valid non-string sequence "
                                        "or mapping object")#.with_traceback(tb)
                l = []
                if not doseq:
                    for k, v in query:
                        if isinstance(k, bytes):
                            k = quote_plus(k, safe)
                        else:
                            k = quote_plus(str(k), safe, encoding, errors)
                        if isinstance(v, bytes):
                            v = quote_plus(v, safe)
                        else:
                            v = quote_plus(str(v), safe, encoding, errors)
                        l.append(k + '=' + v)
                else:
                    for k, v in query:
                        else:
                        elif isinstance(v, str):
                            v = quote_plus(v, safe, encoding, errors)
                        else:
                            try:
                                # Is this a sufficient test for sequence-ness?
                                x = len(v)
                            except TypeError:
                                # not a sequence
                            else:
                                # loop over the sequence
                                for elt in v:
                                    if isinstance(elt, bytes):
                                        elt = quote_plus(elt, safe)
                                    else:
                                        elt = quote_plus(str(elt), safe, encoding, errors)
                                    l.append(k + '=' + elt)
                return '&'.join(l)
            Then we can finally do a nicer GET with parameters:
            import urequests
            from urlencode import urlencode
            url = 'http://server.tld/path/to'
            params = {'key1': 'value1', 'key2': 'value2'}
            if params:
            print(url)
            response = urequests.get(url)
