    M5Paper unique device identifier?
    PRODUCTS
    4.9k
    • G
      gionata
      • ZontexZ
        Zontex
        Hello, does the getEfuseMac return you the same value? you can try to generate a value one time and keep it inside the device for use later.
        • G
          gionata
          Actually, my bad, I ran the same code again on 3 different M5Paper and it is indeed working...
          So yes, getMACString is returning a unique id.
          [global_setting.cpp:70] getMACString(): MAC = 0000CC240805613C
          [main.cpp:261] run(): getEfuseMac: 0805613C
          [global_setting.cpp:70] getMACString(): MAC = 0000CC370805613C
          [global_setting.cpp:70] getMACString(): MAC = 000084170905613C
          [main.cpp:261] run(): getEfuseMac: 0905613C
          • G
            gionata
            Here is a solution to create an unique identifier that is based on the device's MAC address (but is not easy to guess and is not the MAC address itself):
            /** Returns a hashed uint64_t */
            uint64_t getHashedInt64(uint64_t u)
                uint64_t v = u * 3935559000370003845 + 2691343689449507681;
                v ^= v >> 21;
                v ^= v << 37;
                v ^= v >> 4;
                v *= 4768777513237032717;
                v ^= v << 20;
                v ^= v >> 41;
                v ^= v << 5;
                return v;
            /** Return a device unique identifier based on device's mac address, eg. 6C4080B51A5D3659 */
            String getUniqueId()
                uint64_t mac = ESP.getEfuseMac();
                uint64_t hash = getHashedInt64(mac);
                uint32_t msb = hash >> 32;
                uint32_t lsb = hash & 0xFFFFFFFF;
                char unique_id[20];
                sprintf(unique_id, "%08X%08X", msb, lsb);
                return String(unique_id);
            Calling:
            getUniqueId() returns something like 6C4080B51A5D3659
