    Recovering an M5 Atom Lite
    Atom
    6.3k
    • D
      Derek 0
      Something went wrong programming an M5 Atom lite. It made the USB connection permanently busy. The solution was to open the case, adjacent to the USB connector there are two pads marked D0. Shorting these pads while pressing and releasing the reset button enabled the M5 to be reprogrammed. A bricked device was so recovered.
      • m5stackM
        download program time out. maybe is the USB driver firmware problem.
        which system are you use? id
        you could follow this tutorial to upgrade the USB chip version.
        https://forum.m5stack.com/category/34/official-updates
          ajb2k3 @Derek 0
          @derek-0 this is normally the drivers fault. Did you try powering off the computer first?
