    Atom Matrix auto-run?
    2 Posts 2 Posters 4.8k Views
    • dpharrisD Offline
      dpharris
      I cannot get a program to autostart in an Atom Matrix. After I switch modes with button/reset and release at purple, the screen turns black and stays black through reset and power on. I also tried naming it "main", and also "main.py", but no luck.
      What am I doing wrong?
      David
      • m5stackM Offline
        in the FS root path has already had main.py file you could modify it. when you select the app mode(purple) main.py will be exec.
        if you are use UIFlow, you need to download the program, not just exec it. then it will auto setting this program for auto-start running.
        if still not work, pls check the serial log
