Delete apps from M5S-Core
how is it possible to remove some of the apps listed on the device, without wiping the entire device?
I found [here] (https://forum.m5stack.com/topic/2076/m5stack-delete-app-from-app-list-uiflow-v1-5-4/3) some suggestions but it did not work, as the device complains with error.
After loading some UIFlow codes, I'd like to delete them from the device -
You can connect to your device trought a terminal and type/send commands manually (if you have uiflow/micropython firmware on your device)
try these commands:
import os library
import oslist current directory
os.listdir()change current directory to directory_name
os.chdir("directory_name")delete filename.py in current directory
os.remove("filename.py")uiflow store python scripts in apps directory
@robalstona
With the software 'ThonnyPython IDE for beginners'
https://thonny.org/ you can simply delete the apps -
Thanks,
later on I found that in UIFlow (top right corner) there is a button "Manager" that, when pressed, opens a Resource Manager window with a double usage: Images and Blockly. If you select Blockly you get the software app inventory that allows you also to delete the app you want. -
@teiafra
Great tip! I always forget about the resource manager. That is another way to remove apps from the device.
