I have a TAB5 and a M5STAMP-CatM module, there doesn't seem to be any way to connect the 2 The Stamp fits in the aperture in the case and there are pads on the TAB5 PCB but no pins. So do they connect?
Best posts made by scroggyg
TAB5 and Stamp Connector
Latest posts made by scroggyg
RE: Tab5 RS485 connector
I do think it is too fragile to be of any practical use, I am trying to surface mount a TAB5 in a 3D printed bezel but as all the other connections are on the side, it isn't easy
RE: UIFlow TAB5 text scaling
I did a check and set scaling to 1 and the display is properly shown i.e. as 9:59 etc
I had crested an application usingthe Tough, but I was asked if I could use a larger screen. The application is very simple, but part of it displays a countdown clock (mins : Secs). As the fonts supplied are quite small I had to scale the text. On the Tough (without Scaling) worked fine on the TAB5 when the time changes to 9:59 it shows 9:590 and the zero persists. Is there a way to format the clock in UIFlow so it would show 09:59?
RE: Tab5 display issue
I would definitely a hardware problem, probably due to the connection to the display.
Also on the point of heat, the TAB5 seems to draw nearly almost 3 Watts, probably mostly on the larger display back light. I have had great problems powering it because of this. at 12 Volts on the HVIN it draws up to 240mA. -
RE: RS485 on TAB5
Thanks Robski, this is close, but not really the same thing, The Commu module allows native, and simpler RS485, but I will use Modbus.
Thanks -
RS485 on TAB5
I am trying to use RS485 on the TAB5 main board, whilst there is a connector and SIT3088 I can't find UIFlow support for it, there is for the UART and CAN, but not RS485, have I missed something?
Thanks -
RE: Tab5 Wall/Panel Mount
I ended up making a PCB for this, I don't think the fine pitch connectors are sufficiently robust, so I connected to a simple PCB and then used a DC Jack plug on the board. MY 3D enclosure then mounts, via a laser cut plate to a UK double gang backbox
RE: Tab5 Power up sequence
You would need to strap the board to do this. I created a board and getting it made at JLCPCB. The CANPwr board is quite expensive, reasonably enough, it is electrically isolated.
I have now bought both the PWRCAN and the Commu modules, neither apply power to SYSVIN or they do generate 5V on pin 28, which needs to be switched. I am using the TAB5 on a UK double gang plate with a 3D printed Bezel, you can't plug anything into the sides, as they would get removed.
It isn't practical to use the ExtPort2, as I would need to create a custom PCB to connect between the fine pitch fines to add a robust connector, are there any other options to power the TAB5 from behind?
Is there a Comms module ( I what to talk between 2 TAB5s over RS485) with a connector I can power the TAB5 from?
Thanks -
I assume then the correct way to do this would be to use ExtPort2 and connect up to 12V through HVIN?
