    M5Stack 2 Channel Oscilloscope
    20 Posts 8 Posters 66.8k Views 3 Watching
    • dasloloD Offline
      daslolo @Calin
      @calin and the ESP32 can be damaged by spiked above 3.3V, I read. How do I know if I damaged mine?
      I'll add voltage divider, is there a way to remove spikes without killing the sensitivity? I am doing an FFT on the signal and don't want to smooth things out too much.
        Calin
        If the DAC input was damaged, it won't pick up any signal that you feed to it...
          Calin
          Btw... check out the new development: http://forum.m5stack.com/topic/165/m5stack-multiapp-firmware
          • dasloloD Offline
            daslolo
            If I understand this correctly, the ESP32 analog input captures only positive voltage.
            How do I get the full -/+ range in there?
              Calin
              Make a voltage divider with 2 resistors (100k or so...) with one end connected to GND and the other end to 3.3v.
              The middle of the divider connected to oscilloscope input pin.
              Apply input signal to input pin and you get +/- 1.65v input range.
              I designed the code to be used with this divider, that's why, without the divider, the oscilloscope line is at the bottom of the screen.
              Once you connect the divider, the signal line will be at the middle of the screen just like on a normal oscilloscope.
              • dasloloD Offline
                daslolo
                Without the voltage divider, the amplitude is the same, just offset by 1.65v?
                  Calin
                  The max amplitude is 3.3v. With the divider, the amplitude will be -1.65v to +1.65v (total 3.3v) The aplitude can be solved easy with a series of resistors at the imput. To change the input aplitude, replace the 10K resistor on the example below:
                    pkourany @Calin
                    @calin 在 M5Stack 2 Channel Oscilloscope 中说:
                    he amplitude will be -0.65v to +0.65v (total 3.3v)
                    @calin, I think you meant the input signal range will be -1.65v to +1.65v (total 3.3v). :)
                      Calin @pkourany
                      @pkourany 在 M5Stack 2 Channel Oscilloscope 中说:
                      yes. sorry for typo... edited now :)
                      • JJJ Offline
                        JJ @Calin
                        Awesome oscilloscope case - designed by Macsbug - infos here
                        • dasloloD Offline
                          daslolo
                          • ChrisWRC Offline
                            ChrisWR
                            Its restarting every 5 seconds making it useless.. what can be my problem?
                            ChrisWRC 1 Reply Last reply Reply Quote 0
                            • ChrisWRC Offline
                              ChrisWR @ChrisWR
                              @chriswr Ok solved.. disable the watchdog..
                              disableCore0WDT();
                              disableCore1WDT();
