About Hat 8servos
I trying m5stickC+Hat 8servos, when I use UiFlow blocky code, it not work!
But I use arduino code, it work.
UiFlow version is 1.4.2
Can you share a screen shot of you UIFlow code please?
I record a mp4 video. The RGB worked but Servo not.
https://youtu.be/iymi3ziUE7M
if you put pressure on the servo horn, does the horn move?
@ajb2k3 said in About Hat 8servos:
pressure
When the program is executed, the pressure on the servo horn is rotatable.
@coffeeworm
Sounds like your not getting power.
@coffeeworm said in About Hat 8servos:
pressure
as @Xeon replied, you dont have power to the servos. is the power switch in the correct position?
Yes,the power is switch in the correct position.
I am sure that it is not a power problem.
I found a solution, I have to set it up first, then the servo can work.
Thank you for your response.
Ah, that is worth Knowing thanks.
I haven't got one yet so didn't know that they needed a "Initial Position" set up.
Thank you for working this out.
