I found a solution, I have to set it up first, then the servo can work.
Thank you for your response.
Best posts made by coffeeworm
RE: About Hat 8servosposted in UIFlow
Latest posts made by coffeeworm
Can't burn fireware toTimer Camera X with M5burnerposted in PRODUCTS
I want to use M5BURNER to burn the firmware but it is unsuccessful.
After I press the BURN button and set the WIFI information, the burning process is not started. -
關於使用M5Stack core連接8servo Hat的問題posted in UIFlow
雖然8servo Hat是為stick設計的,但是有沒有可能用M5Stack core連接它,並且使用UIFlow的積木來操緃?
Thank you for your response. -
@ajb2k3 said in About Hat 8servos:
you dont have power to the servos. is the power switch in the correct position?
Yes,the power is switch in the correct position.
I am sure that it is not a power problem. -
pressure
When the program is executed, the pressure on the servo horn is rotatable.
I record a mp4 video. The RGB worked but Servo not.
https://youtu.be/iymi3ziUE7M -
I trying m5stickC+Hat 8servos, when I use UiFlow blocky code, it not work!
But I use arduino code, it work.
UiFlow version is 1.4.2
