    Lesson 14. UI Flow. Hello M5 UI Flow
    Scheduled Pinned Locked Moved Lessons and Guides
    14 Posts 10 Posters 74.0k Views 3 Watching
    • L Offline
      lveronese
      What about M5Burner for Mac OS ? Are you going to release it in the future?
      Luciano
      • G Offline
        gadjet
        All flashes OK and detects the network OK but after the reset and the long press of "upload" it will not reconnect to the WiFi network ??? any one any ideas?
        • m5-docsM Offline
          m5-docs @ajb2k3
          @ajb2k3 You can burn the firmware via M5Burner
          Here is the article guide you for burning
          https://m5stack.readthedocs.io/en/latest/get-started/how_to_burn_firmware_en.html
          M5Stack documentation URL
          https://docs.m5stack.com
          • m5-docsM Offline
            m5-docs @fab
            @fab Thanks gay
            • m5-docsM Offline
              m5-docs @gadjet
              @gadjet Is that problem exiting still? Try to reset your board again. Sometime, it is a problem about LAN network
              • m5-docsM Offline
                m5-docs
                To everyone:
                Please download lastest version of M5Burner from official website
                www.m5stack.com
                  cpyarger @Julian
                  @julian 在 Lesson 14. UI Flow. Hello M5 UI Flow 中说:
                  @dimi Nice start but how do we include other libraries so we can interface to other systems over http/mqtt/etc?
                  Also Curious about this
                  yuriklebY 1 Reply Last reply Reply Quote 0
                    Following the video on an OSX 10.12.6 using python 3.7 but getting the following when trying to connect.
                    File "./tools/esptool.py", line 2853, in <module>
                    _main()
                    File "./tools/esptool.py", line 2846, in _main
                    main()
                    File "./tools/esptool.py", line 2554, in main
                    esp.connect(args.before)
                    File "./tools/esptool.py", line 446, in connect
                    last_error = self._connect_attempt(mode=mode, esp32r0_delay=False)
                    File "./tools/esptool.py", line 405, in _connect_attempt
                    self._setRTS(True) # EN=LOW, chip in reset
                    File "./tools/esptool.py", line 377, in _setRTS
                    self._port.setDTR(self._port.dtr)
                    AttributeError: 'Serial' object has no attribute 'dtr'
                    However arduino is connecting with no trouble??
                    • yuriklebY Offline
                      yurikleb @cpyarger
                      @cpyarger it basically runs microPython so you can import any module supported by micro python.
                      For example to connect to a wifi hotspot you can import the "network" module:
                      https://docs.micropython.org/en/latest/esp8266/quickref.html#networking
                      To upload custom files/modules you can use "adafruit ampy" or any of the other tools described in this tutorial: https://learn.adafruit.com/micropython-basics-load-files-and-run-code/overview
                      just make sure you upload them to the /flash/ folder.
                      Another useful thing is the REPL which allows you to see the MicroPython Log, very useful to debug your code and see what's happening in the background as not everything can be seen in the LCD:
                      https://docs.micropython.org/en/latest/wipy/tutorial/repl.html
                      The ESP32 also supports the WebREPL:
                      https://micropython.org/webrepl/
                        Alpine-Lake @m5-docs
                        @m5-docs This link points to a " page not available yet" message
