    Lesson 14. UI Flow. Hello M5 UI Flow
    Lessons and Guides
    10
    14
    71.5k
      How do non windows users get the firmware on our m5's?
      • F
        fab
        See http://blog.akanumahiroaki.com/entry/2018/09/08/230000
        • J
          Julian @Dimi
          @dimi Nice start but how do we include other libraries so we can interface to other systems over http/mqtt/etc?
          • L
            lveronese
            What about M5Burner for Mac OS ? Are you going to release it in the future?
            Luciano
            • G
              gadjet
              All flashes OK and detects the network OK but after the reset and the long press of "upload" it will not reconnect to the WiFi network ??? any one any ideas?
              • m5-docsM
                m5-docs @ajb2k3
                @ajb2k3 You can burn the firmware via M5Burner
                Here is the article guide you for burning
                https://m5stack.readthedocs.io/en/latest/get-started/how_to_burn_firmware_en.html
                M5Stack documentation URL
                https://docs.m5stack.com
                • m5-docsM
                  m5-docs @fab
                  @fab Thanks gay
                  • m5-docsM
                    m5-docs @gadjet
                    @gadjet Is that problem exiting still? Try to reset your board again. Sometime, it is a problem about LAN network
                    • m5-docsM
                      m5-docs
                      To everyone:
                      Please download lastest version of M5Burner from official website
                      www.m5stack.com
                      • C
                        cpyarger @Julian
                        @julian 在 Lesson 14. UI Flow. Hello M5 UI Flow 中说:
                        Also Curious about this
                        yuriklebY 1 Reply Last reply Reply Quote 0
                          Following the video on an OSX 10.12.6 using python 3.7 but getting the following when trying to connect.
                          File "./tools/esptool.py", line 2853, in <module>
                          _main()
                          File "./tools/esptool.py", line 2846, in _main
                          main()
                          File "./tools/esptool.py", line 2554, in main
                          esp.connect(args.before)
                          File "./tools/esptool.py", line 446, in connect
                          last_error = self._connect_attempt(mode=mode, esp32r0_delay=False)
                          File "./tools/esptool.py", line 405, in _connect_attempt
                          self._setRTS(True) # EN=LOW, chip in reset
                          File "./tools/esptool.py", line 377, in _setRTS
                          self._port.setDTR(self._port.dtr)
                          AttributeError: 'Serial' object has no attribute 'dtr'
                          However arduino is connecting with no trouble??
                          • yuriklebY
                            yurikleb @cpyarger
                            @cpyarger it basically runs microPython so you can import any module supported by micro python.
                            For example to connect to a wifi hotspot you can import the "network" module:
                            https://docs.micropython.org/en/latest/esp8266/quickref.html#networking
                            To upload custom files/modules you can use "adafruit ampy" or any of the other tools described in this tutorial: https://learn.adafruit.com/micropython-basics-load-files-and-run-code/overview
                            just make sure you upload them to the /flash/ folder.
                            Another useful thing is the REPL which allows you to see the MicroPython Log, very useful to debug your code and see what's happening in the background as not everything can be seen in the LCD:
                            https://docs.micropython.org/en/latest/wipy/tutorial/repl.html
                            The ESP32 also supports the WebREPL:
                            https://micropython.org/webrepl/
                            • A
                              Alpine-Lake @m5-docs
                              @m5-docs This link points to a " page not available yet" message
