    69 Posts 7 Posters 430.6k Views 1 Watching
      salty_good @ajb2k3
      @ajb2k3 Off course yes,
      and Baudrate also needs to be selectable.
      • G Offline
        GACHAPO @m5-docs
        @watson Thanks - I have amended this. Am I best to use Arduino IDE to compile and upload? Currently when I use Arduino I have several error messages.
        • m5-docsM Offline
          m5-docs @GACHAPO
          Hello @gachapo It's best to use esp-idf.
          M5Stack documentation URL
          https://docs.m5stack.com
          • G Offline
            GACHAPO @m5-docs
            @watson Thanks- can you use arduino-ide?
            • m5-docsM Offline
              m5-docs @GACHAPO
              Hello @gachapo,
              Yes, Color recognition arduino program may help you.
              Here's the code:
              https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L36
              • G Offline
                GACHAPO @m5-docs
                @watson Thank you.
                Do I choose CAMERA_MODEL_WROVER_KIT?
                • m5-docsM Offline
                  m5-docs @GACHAPO
                  @gachapo
                  You need chang this source code about camera hardware configuration for adapting to ESP32CAM. Because the arduino source code is for M5Camera A model.
                  // Select camera model
                  //#define CAMERA_MODEL_WROVER_KIT
                  #define CAMERA_A_MODEL_M5STACK_PSRAM
                  //#define CAMERA_MODEL_AI_THINKER
                  • m5-docsM Offline
                    m5-docs
                    @GACHAPO @ajb2k3 Thanks your support
                    • G Offline
                      GACHAPO @m5-docs
                      @watson I have downloaded the M5CamColourRecognition.ino and uploaded to camera successfully. I now have an issued IP address to my network, which I have browsed to and the software loads. However, when I either click get picture or start stream it doesn't work. Please advise?
                      • m5-docsM Offline
                        m5-docs @GACHAPO
                        @gachapo Do you modify those pin map for adapting to ESP32CAM not M5Camera (A model)?
                        https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L62
                        #elif defined(CAMERA_A_MODEL_M5STACK_PSRAM)
                        #define PWDN_GPIO_NUM     -1
                        #define RESET_GPIO_NUM    15
                        #define XCLK_GPIO_NUM     27
                        #define SIOD_GPIO_NUM     25
                        #define SIOC_GPIO_NUM     23
                        #define Y9_GPIO_NUM       19
                        #define Y8_GPIO_NUM       36
                        #define Y7_GPIO_NUM       18
                        #define Y6_GPIO_NUM       39
                        #define Y5_GPIO_NUM        5
                        #define Y4_GPIO_NUM       34
                        #define Y3_GPIO_NUM       35
                        #define Y2_GPIO_NUM       32
                        #define VSYNC_GPIO_NUM    22
                        #define HREF_GPIO_NUM     26
                        #define PCLK_GPIO_NUM     21
                        • G Offline
                          GACHAPO
                          Yes, as far as I'm aware as long as I have chosen the correct (or in this case closest match) at the top the defined pins should be loaded as below;
                          • m5-docsM Offline
                            m5-docs @GACHAPO
                            @gachapo
                            • G Offline
                              GACHAPO
                              Hello - I've downloaded before but I don't think it has .ino files so can't be used with Arduino.ide. Please advise?
                                ajb2k3 @GACHAPO
                                @gachapo said in [Solved] M5 Burner Firmware Option Update:
                                No, the driver is compiled with the espressiv IDF and so you need to install that and configure it to compile.
                                Something I have failed to do several times now.
                                • m5-docsM Offline
                                  m5-docs
                                  can also program with arduino ide
                                  • G Offline
                                    GACHAPO @m5-docs
                                    @watson Ok - so frustrated was I with my first attempt I purchased a M5Camera ESP32 PSRAM. Works out of the box nicely, but only on it's own wifi (192.168.4.1). However, as previously I need to get onto my network.
                                    Therefore, using Arduino IDE I have gone to File, Examples, ESP32, Camera nd loaded up the sketch from there.
                                    I have then amended the SSID and Password to my own and defined the PSRAM camera as below;
                                    Compiles and uploaded the sketch.
                                    Nothing! - Camera doesn't even turn on.
                                    Can somebody please, simply tell me where I am going wrong and how you ever get this great product on your own network.
                                    • O Offline
                                      Oyye @GACHAPO
                                      @gachapo
                                      I just registered for you :D
                                      Here what is solved my problem (Y2_GPIO_NUM):
                                      #elif defined(CAMERA_MODEL_M5STACK_PSRAM)
                                      #define Y2_GPIO_NUM 17 //32
                                      ajb2k3A G 2 Replies Last reply Reply Quote 0
                                        ajb2k3 @Oyye
                                        @oyye said in [Solved] M5 Burner Firmware Option Update:
                                        @gachapo
                                        Welcome to the forum!
                                        • G Offline
                                          GACHAPO @Oyye
                                          @oyye Thank-you,
                                          I did as you stated with only change from the Arduino Examples being;
                                          This has made no change - Camera still does not come on.
                                          Just to be absolutely clear - this is the camera a have
                                          ![0_1556260445735_20190426_073011.jpg](Uploading 100%)
                                          • G Offline
                                            GACHAPO
                                            Is anybody able to help me please? I now have 2 cameras and I am completely unable to get them on my wifi network as intended. Thank you
