    69 Posts 7 Posters 430.6k Views 1 Watching
      salty_good
      I understood this problem.
      We need to fix M5Burner for mac.
        ajb2k3 @salty_good
        @salty_good said in [updated for Camera boards] M5 Burner Firmware Option Update:
        Can you add drop down box to select port?
        ポートを選択するためのドロップダウンボックスを追加できますか?
        • m5-docsM Offline
          m5-docs @GACHAPO
          M5Stack documentation URL
          https://docs.m5stack.com
            salty_good @ajb2k3
            @ajb2k3 Off course yes,
            and Baudrate also needs to be selectable.
            • G Offline
              GACHAPO @m5-docs
              @watson Thanks - I have amended this. Am I best to use Arduino IDE to compile and upload? Currently when I use Arduino I have several error messages.
              • m5-docsM Offline
                m5-docs @GACHAPO
                Hello @gachapo It's best to use esp-idf.
                • G Offline
                  GACHAPO @m5-docs
                  @watson Thanks- can you use arduino-ide?
                  • m5-docsM Offline
                    m5-docs @GACHAPO
                    Hello @gachapo,
                    Yes, Color recognition arduino program may help you.
                    Here's the code:
                    https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L36
                    • G Offline
                      GACHAPO @m5-docs
                      @watson Thank you.
                      Do I choose CAMERA_MODEL_WROVER_KIT?
                      • m5-docsM Offline
                        m5-docs @GACHAPO
                        @gachapo
                        You need chang this source code about camera hardware configuration for adapting to ESP32CAM. Because the arduino source code is for M5Camera A model.
                        // Select camera model
                        //#define CAMERA_MODEL_WROVER_KIT
                        #define CAMERA_A_MODEL_M5STACK_PSRAM
                        //#define CAMERA_MODEL_AI_THINKER
                        • m5-docsM Offline
                          m5-docs
                          @GACHAPO @ajb2k3 Thanks your support
                          • G Offline
                            GACHAPO @m5-docs
                            @watson I have downloaded the M5CamColourRecognition.ino and uploaded to camera successfully. I now have an issued IP address to my network, which I have browsed to and the software loads. However, when I either click get picture or start stream it doesn't work. Please advise?
                            • m5-docsM Offline
                              m5-docs @GACHAPO
                              @gachapo Do you modify those pin map for adapting to ESP32CAM not M5Camera (A model)?
                              https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L62
                              #elif defined(CAMERA_A_MODEL_M5STACK_PSRAM)
                              #define PWDN_GPIO_NUM     -1
                              #define RESET_GPIO_NUM    15
                              #define XCLK_GPIO_NUM     27
                              #define SIOD_GPIO_NUM     25
                              #define SIOC_GPIO_NUM     23
                              #define Y9_GPIO_NUM       19
                              #define Y8_GPIO_NUM       36
                              #define Y7_GPIO_NUM       18
                              #define Y6_GPIO_NUM       39
                              #define Y5_GPIO_NUM        5
                              #define Y4_GPIO_NUM       34
                              #define Y3_GPIO_NUM       35
                              #define Y2_GPIO_NUM       32
                              #define VSYNC_GPIO_NUM    22
                              #define HREF_GPIO_NUM     26
                              #define PCLK_GPIO_NUM     21
                              • G Offline
                                GACHAPO
                                Yes, as far as I'm aware as long as I have chosen the correct (or in this case closest match) at the top the defined pins should be loaded as below;
                                • m5-docsM Offline
                                  m5-docs @GACHAPO
                                  @gachapo
                                  • G Offline
                                    GACHAPO
                                    Hello - I've downloaded before but I don't think it has .ino files so can't be used with Arduino.ide. Please advise?
                                      ajb2k3 @GACHAPO
                                      @gachapo said in [Solved] M5 Burner Firmware Option Update:
                                      No, the driver is compiled with the espressiv IDF and so you need to install that and configure it to compile.
                                      Something I have failed to do several times now.
                                      • m5-docsM Offline
                                        m5-docs
                                        can also program with arduino ide
                                        • G Offline
                                          GACHAPO @m5-docs
                                          @watson Ok - so frustrated was I with my first attempt I purchased a M5Camera ESP32 PSRAM. Works out of the box nicely, but only on it's own wifi (192.168.4.1). However, as previously I need to get onto my network.
                                          Therefore, using Arduino IDE I have gone to File, Examples, ESP32, Camera nd loaded up the sketch from there.
                                          I have then amended the SSID and Password to my own and defined the PSRAM camera as below;
                                          Compiles and uploaded the sketch.
                                          Nothing! - Camera doesn't even turn on.
                                          Can somebody please, simply tell me where I am going wrong and how you ever get this great product on your own network.
                                          • O Offline
                                            Oyye @GACHAPO
                                            @gachapo
                                            I just registered for you :D
                                            Here what is solved my problem (Y2_GPIO_NUM):
                                            #elif defined(CAMERA_MODEL_M5STACK_PSRAM)
                                            #define Y2_GPIO_NUM 17 //32
                                            ajb2k3A G 2 Replies Last reply Reply Quote 0
