    TAB5: Unable to mount SD card as USB mass storage
    PRODUCTS
    5
    981
    • V
      vitalEOL
      I'm trying to get the SD2USBMSC example (https://github.com/espressif/arduino-esp32/tree/master/libraries/SD_MMC/examples/SD2USBMSC) running on my M5TAB5
      I have been able to get the same example running on an ESP32-S3 board & now I want to test the High Speed USB of the ESP32-P4 in the Tab5.
      I have the sketch running on my Tab5 and the SD card appears to be detected & mounted correctly; at run-time I get USB UNPLUGGED reported (ARDUINO_USB_STOPPED_EVENT).
      I have powered the Tab5 externally via the posts on the battery slot but I do not see events reported for the other USB events:
      • ARDUINO_USB_STARTED_EVENT
      • ARDUINO_USB_SUSPEND_EVENT
      • ARDUINO_USB_RESUME_EVENT
      Below is the log from the device
      EESP-ROM:esp32p4-eco2-20240710
      Build:Jul 10 2024
      rst:0x1 (POWERON),boot:0x20f (SPI_FAST_FLASH_BOOT)
      SPI mode:DIO, clock div:1
      load:0x4ff33ce0,len:0x118c
      load:0x4ff2abd0,len:0xcd0
      load:0x4ff2cbd0,len:0x3304
      entry 0x4ff2abd0
      Build:Jul 10 2024
      rst:0x7 (HP_SYS_HP_WDT_RESET),boot:0x20f (SPI_FAST_FLASH_BOOT)
      entry 0x4ff2abd0
      [     1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400138a8
      [    12][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x40013866
      [    23][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x40013824
      [    35][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400137e2
      [    46][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400138a8
      [    57][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x40013866
      [    68][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x40013824
      [    80][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400137e2
      [    91][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400138a8
      [   102][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x40013866
      [   114][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x40013824
      [   125][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400137e2
      [   136][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400138a8
      [   147][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x40013866
      [   159][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x40013824
      [   170][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400137e2
      [   181][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400138a8
      [   193][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x40013866
      [   204][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x40013824
      [   215][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400137e2
      [   226][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400138a8
      [   238][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x40013866
      [   249][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x40013824
      [   260][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400137e2
      [   272][D][esp32-hal-tinyusb.c:806] tinyusb_enable_interface2(): Interface MSC enabled
      [   286][I][esp32-hal-psram.c:102] psramAddToHeap(): PSRAM added to the heap.
      [   297][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 38 successfully set to type UART_RX (2) with bus 0x4ff11048
      [   308][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 37 successfully set to type UART_TX (3) with bus 0x4ff11048
      =========== Before Setup Start ===========
      Chip Info:
        Model             : ESP32-P4
        Package           : 0
        Revision          : 1.00
        Cores             : 2
        CPU Frequency     : 360 MHz
        XTAL Frequency    : 40 MHz
        Features Bitfield : 0000000000
        Embedded Flash    : No
        Embedded PSRAM    : No
        2.4GHz WiFi       : No
        Classic BT        : No
        BT Low Energy     : No
        IEEE 802.15.4     : No
      INTERNAL Memory Info:
        Total Size        :   572780 B ( 559.4 KB)
        Free Bytes        :   544996 B ( 532.2 KB)
        Allocated Bytes   :    21964 B (  21.4 KB)
        Minimum Free Bytes:   540020 B ( 527.4 KB)
        Largest Free Block:   385012 B ( 376.0 KB)
      SPIRAM Memory Info:
        Total Size        : 33554432 B (32768.0 KB)
        Free Bytes        : 33551856 B (32765.5 KB)
        Allocated Bytes   :        0 B (   0.0 KB)
        Minimum Free Bytes: 33551856 B (32765.5 KB)
        Largest Free Block: 33030132 B (32256.0 KB)
        Bus Mode          : QSPI
      Flash Info:
        Chip Size         : 16777216 B (16 MB)
        Block Size        :    65536 B (  64.0 KB)
        Sector Size       :     4096 B (   4.0 KB)
        Page Size         :      256 B (   0.2 KB)
        Bus Speed         : 80 MHz
        Bus Mode          : QIO
      Partitions Info:
                      nvs : addr: 0x00009000, size:    20.0 KB, type: DATA, subtype: NVS
                  otadata : addr: 0x0000E000, size:     8.0 KB, type: DATA, subtype: OTA
                     app0 : addr: 0x00010000, size:  6400.0 KB, type:  APP, subtype: OTA_0
                     app1 : addr: 0x00650000, size:  6400.0 KB, type:  APP, subtype: OTA_1
                   spiffs : addr: 0x00C90000, size:  3456.0 KB, type: DATA, subtype: SPIFFS
                 coredump : addr: 0x00FF0000, size:    64.0 KB, type: DATA, subtype: COREDUMP
      Software Info:
        Compile Date/Time : Sep 10 2025 11:23:03
        Compile Host OS   : windows
        ESP-IDF Version   : v5.4.2-25-g858a988d6e
        Arduino Version   : 3.2.1
      Board Info:
        Arduino Board     : M5STACK_TAB5
        Arduino Variant   : m5stack_tab5
        Arduino FQBN      : m5stack:esp32:m5stack_tab5:UploadSpeed=921600,USBMode=default,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=360,FlashFreq=80,FlashMode=qio,FlashSize=16M,PartitionScheme=default,DebugLevel=verbose,PSRAM=enabled,EraseFlash=none,JTAGAdapter=builtin
      ============ Before Setup End ============
      [   673][V][esp32-hal-uart.c:676] uartBegin(): UART0 baud(115200) Mode(800001c) rxPin(38) txPin(37)
      [   682][V][esp32-hal-uart.c:774] uartBegin(): UART0 not installed. Starting installation
      [   690][V][esp32-hal-uart.c:784] uartBegin(): UART0 RX FIFO full threshold set to 120 (value requested: 120 || FIFO Max = 128)
      [   701][V][esp32-hal-uart.c:810] uartBegin(): Setting UART0 to use XTAL clock
      [   709][V][esp32-hal-uart.c:874] uartBegin(): UART0 initialization done.
      [   715][V][esp32-hal-uart.c:925] uartSetRxFIFOFull(): UART0 RX FIFO Full value set to 120 from a requested value of 120
      Starting Serial
      Mounting SDcard
      [   726][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type SDMMC_CLK (38) successfully set to 0x4000b840
      [   740][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type SDMMC_CMD (39) successfully set to 0x4000b840
      [   752][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type SDMMC_D0 (40) successfully set to 0x4000b840
      [   763][D][SD_MMC.cpp:188] begin(): pin_cmd: 44, pin_clk: 43, pin_d0: 39, pin_d1: 40, pin_d2: 41, pin_d3: 42
      [   773][I][SD_MMC.cpp:252] begin(): On-chip power channel specified, use external power for SDMMC
      [   846][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 44 successfully set to type SDMMC_CMD (39) with bus 0x4ff142f8
      [   857][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 43 successfully set to type SDMMC_CLK (38) with bus 0x4ff142f8
      [   868][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 39 successfully set to type SDMMC_D0 (40) with bus 0x4ff142f8
      Initializing MSC
      Initializing USB
      [   879][D][esp32-hal-tinyusb.c:684] tinyusb_load_enabled_interfaces(): Load Done: if_num: 1, descr_len: 32, if_mask: 0x1
      Card Size: 7447MB
                       Sector: 512    Count: 15251456
                                                     =========== After Setup Start ============
      USB UNPLUGGED
        Free Bytes        :   538448 B ( 525.8 KB)
        Allocated Bytes   :    28064 B (  27.4 KB)
        Minimum Free Bytes:   538428 B ( 525.8 KB)
      SPIRAM Memory Info:
        Free Bytes        : 33520032 B (32734.4 KB)
        Allocated Bytes   :    31584 B (  30.8 KB)
        Minimum Free Bytes: 33520032 B (32734.4 KB)
      GPIO Info:
        GPIO : BUS_TYPE[bus/unit][chan]
          37 : UART_TX[0]
          38 : UART_RX[0]
          39 : SDMMC_D0
          43 : SDMMC_CLK
          44 : SDMMC_CMD
      ============ After Setup End =============
      Has anyone had any luck (or problems) with getting this working on the Tab5 device?
      Appreciate any help/direction...
      • henryCharmH
        henryCharm
        From what you described and the logs, it looks like the SD card is being detected and mounted correctly, but the USB MSC interface reports USB UNPLUGGED (ARDUINO_USB_STOPPED_EVENT). This usually means the USB host (e.g., your PC) is not recognizing the device as connected or the USB device stack on the ESP32-P4 isn’t properly signaling a connection.
        check:
        • Make sure the USB data lines (D+ and D-) and power (VBUS) are hooked up right. If you’re just powering through the battery spots without the USB power line, the computer might think the device is unplugged.
        • Check that the USB Mass Storage mode is turned on in your code and board settings.
        • Use the latest ESP32-P4 USB support in Arduino or ESP-IDF. Sometimes the USB stuff on this chip can be a bit tricky.
        • If you don’t see USB started or resume messages, the USB connection might not be working properly or the computer isn’t recognizing the device.
        • Run a basic USB example (like USB serial or simple storage) to see if USB itself works, without the SD card part.
        • Make sure the pins for SD card and USB don’t clash with each other or other parts.
        this is all I can think off
        From a Data Science Intern to now happy as a IoT Solutions Architect.
        V 1 Reply Last reply Reply Quote 0
        • V
          vitalEOL @henryCharm
          @henryCharm
          Thanks for the feedback.
          I have tried several examples from both the Arduino & IDF (both updated to the latest) and none of them seem to expose the Tab5 as a usb device:
          • USB Keyboard & Mouse examples
          • USB Custom HID device
          • USBMSC example
          • USB Serial example
          I can get similar projects working on my ESP32-S3 device without issue..
          I'm wondering if anyone has a working example of the Tab5 enumerating as a USB device?
          • R
            rkirchne
            I'm having the same issue with my Tab5, when I try USBMSC or SD2USBMSC examples in Arduino IDE they upload fine but I don't get a usb device on my computer. I did notice in the serial monitor that it says USB-Serial/JTAG, even though I changed the settings under tools, following this fellows video:
            https://www.youtube.com/watch?v=hJSBTFsOnoA
            He's using a ESP32-S3 and it seems to work fine. One thing I did discover in the ESP32-P4 docs is that it needs the strapping pins set in order to get the chip in Joint download mode:
            https://docs.espressif.com/projects/esp-hardware-design-guidelines/en/latest/esp32p4/schematic-checklist-esp32p4.html#schematic-checklist-strapping-pins
            It also can share the same lines for USB:
            https://docs.espressif.com/projects/esp-hardware-design-guidelines/en/latest/esp32p4/schematic-checklist-esp32p4.html#usb
            I think the usb-c might be connected to both sets of lines and the pins are not set correctly to select joint download mode. I couldn't really determine this in the schematics provided by M5 as they are confusing but I think they need to provide separate examples and libraries for the ESP32-P4 as it is quite different from the ESP32-S3
            • Tinyu.ZhaoT
              Tinyu.Zhao Global Moderator
              Using this example is fine.
              https://github.com/espressif/esp-idf/tree/master/examples/peripherals/usb/device/tusb_msc
              sdkconfig.defaults
              # This file was generated using idf.py save-defconfig. It can be edited manually.
              # Espressif IoT Development Framework (ESP-IDF) 5.5.1 Project Minimal Configuration
              CONFIG_IDF_TARGET="esp32p4"
              CONFIG_ESPTOOLPY_FLASHSIZE_4MB=y
              CONFIG_PARTITION_TABLE_CUSTOM=y
              CONFIG_EXAMPLE_STORAGE_MEDIA_SDMMC=y
              CONFIG_EXAMPLE_SD_PWR_CTRL_LDO_INTERNAL_IO=n
              CONFIG_ESP_CONSOLE_USB_SERIAL_JTAG=y
              CONFIG_FATFS_LFN_HEAP=y
              CONFIG_WL_SECTOR_SIZE_512=y
              CONFIG_WL_SECTOR_MODE_PERF=y
              CONFIG_TINYUSB_MSC_ENABLED=y
