    M5Apps - multiple apps installer
    PROJECTS
    6
    13
    5.0k
    • D
      d4rkmen @d4rkmen
      @d4rkmen v1.2 comes with WiFi scan feature and more free flash space for apps.
      The Cloud repository:
      M5Burner for burner mirror in convenient way.
      TOP-20 for best apps tested by me
      • E
        erwantest123
        hello i have a error with sha256 verification
        bye
        P.S. i love your project
        serial logs:
        [FROM M5Burner] COM3 opened.
        load:0x600fe100,len:0x1c
        SHA-256 comparison failed:
        Calculated: 5e23c97eab19023e851de85f4eeea87aed472ea13e871562b17f2a5ec097a9f5
        Expected: 1108a20e982d1031358092f5f1acb0437a206312e99d5443a1985793bd2c5984
        Attempting to boot anyway...
        entry 0x40375408
        ESP-ROM:esp32s3-20210327
        Build:Mar 27 2021
        rst:0x7 (TG0WDT_SYS_RST),boot:0x2b (SPI_FAST_FLASH_BOOT)
        Saved PC:0x40389f10
        SPIWP:0xee
        mode:DIO, clock div:1
        load:0x3c0f0020,len:0xc91a8
        load:0x3fc9a100,len:0x4ba8
        load:0x40374000,len:0x2298
        load:0x42000020,len:0xe5b9c
        load:0x40376298,len:0x13e40
        entry 0x40375408
        Build:Mar 27 2021
        Saved PC:0x403743c0
        SPIWP:0xee
        [FROM M5Burner] Serial Port Disconnected.
        • D
          d4rkmen @erwantest123
          @erwantest123 wow, first feedback :)
          thanks for this. whould be nice to have steps to reproduce
          • E
            erwantest123
            hello 1.3 work for me
            thank you
            • D
              @erwantest123 was my fault. I have put single app file to M5Burner isntead of full fw :(
              Check for new TOP-20 updates:
              • Snake: classic game
              • M5Tuna: guitar tuner app
              Both apps are ~350Kb, could be used with M5Apps very well
              • D
                d4rkmen
                v1.5
                • Added version to boot animation
                • Cloud source error messages are now more informative
                • Minor UI fixes (hints, navigation, sound)
                • B
                  bigchease
                  this might be a dumb question but is there any way to get a bin file for m5 launcher
                  • D
                    d4rkmen @bigchease
                    @bigchease no, you have to flash full firmware (bootloader, PT, nvs, and the rest). Thans why you have to use some other flasher like M5Burner or esptools.
                    • K
                      kermit17 @d4rkmen
                      @d4rkmen
                      Hi, are you talking about M5 Launcher project or something different?
                      I'm confused (new user) as the version numbers seem very different between what you say and what I see on M5 Burner.
                      PS is there any chance of something like this for Tab5?
                      • ImLunchtimeI
                        ImLunchtime
                        Would this project ever be open-source? I was trying to create such a firmware manager for my Tab5 device and was encountering troubles, the M5Launcher's approach was strange (seems like it needs a custom bootloader which I don't have) so I wanted to check M5Apps out. It would be the best if M5Apps are open source.
                        • Y
                          yehors
                          If this broke your cardputer here is how to fix it:
                          Before plugging your cardputer in hold the GO button and then plug in the cable. Cardputer will enter the download mode and you can then flash everything you want!
                          ~ yehor
