    M5Apps - multiple apps installer
    PROJECTS
    7
    14
    5.1k
    • D
      d4rkmen
      Check out the new project for firmware flashing right on your M5 Cardputer (currently under development)
      Supported features:
      • Install app in separate partition (in case the image is single app partition)
      • Install full firmware bundle (erasing all previous installed apps)
      • Press any key on boot to enter Apps menu
      • List of installed apps. Run immediately
      Supported sources (media):
      • SD card (FAT formatted)
      • USB flash drive (FAT formated)
      • Remote repository (under development)
      Version 1.0 is available in M5Burner under CARDPUTER device.
      Waiting for feedback.
      D 1 Reply Last reply Reply Quote 2
      • D
        d4rkmen @d4rkmen
        v1.1 is out and its crazy
        • D
          d4rkmen @d4rkmen
          @d4rkmen v1.2 comes with WiFi scan feature and more free flash space for apps.
          The Cloud repository:
          M5Burner for burner mirror in convenient way.
          TOP-20 for best apps tested by me
          • E
            erwantest123
            hello i have a error with sha256 verification
            bye
            P.S. i love your project
            serial logs:
            [FROM M5Burner] COM3 opened.
            load:0x600fe100,len:0x1c
            SHA-256 comparison failed:
            Calculated: 5e23c97eab19023e851de85f4eeea87aed472ea13e871562b17f2a5ec097a9f5
            Expected: 1108a20e982d1031358092f5f1acb0437a206312e99d5443a1985793bd2c5984
            Attempting to boot anyway...
            entry 0x40375408
            ESP-ROM:esp32s3-20210327
            Build:Mar 27 2021
            rst:0x7 (TG0WDT_SYS_RST),boot:0x2b (SPI_FAST_FLASH_BOOT)
            Saved PC:0x40389f10
            SPIWP:0xee
            mode:DIO, clock div:1
            load:0x3c0f0020,len:0xc91a8
            load:0x3fc9a100,len:0x4ba8
            load:0x40374000,len:0x2298
            load:0x42000020,len:0xe5b9c
            load:0x40376298,len:0x13e40
            entry 0x40375408
            Build:Mar 27 2021
            Saved PC:0x403743c0
            SPIWP:0xee
            [FROM M5Burner] Serial Port Disconnected.
            • D
              d4rkmen @erwantest123
              @erwantest123 wow, first feedback :)
              thanks for this. whould be nice to have steps to reproduce
              • E
                erwantest123
                hello 1.3 work for me
                thank you
                • D
                  @erwantest123 was my fault. I have put single app file to M5Burner isntead of full fw :(
                  Check for new TOP-20 updates:
                  • Snake: classic game
                  • M5Tuna: guitar tuner app
                  Both apps are ~350Kb, could be used with M5Apps very well
                  • D
                    d4rkmen
                    v1.5
                    • Added version to boot animation
                    • Cloud source error messages are now more informative
                    • Minor UI fixes (hints, navigation, sound)
                    • B
                      bigchease
                      this might be a dumb question but is there any way to get a bin file for m5 launcher
                      • D
                        d4rkmen @bigchease
                        @bigchease no, you have to flash full firmware (bootloader, PT, nvs, and the rest). Thans why you have to use some other flasher like M5Burner or esptools.
                        • K
                          kermit17 @d4rkmen
                          @d4rkmen
                          Hi, are you talking about M5 Launcher project or something different?
                          I'm confused (new user) as the version numbers seem very different between what you say and what I see on M5 Burner.
                          PS is there any chance of something like this for Tab5?
                          • ImLunchtimeI
                            ImLunchtime
                            Would this project ever be open-source? I was trying to create such a firmware manager for my Tab5 device and was encountering troubles, the M5Launcher's approach was strange (seems like it needs a custom bootloader which I don't have) so I wanted to check M5Apps out. It would be the best if M5Apps are open source.
                            • Y
                              yehors
                              If this broke your cardputer here is how to fix it:
                              Before plugging your cardputer in hold the GO button and then plug in the cable. Cardputer will enter the download mode and you can then flash everything you want!
                              ~ yehor
                              • T
                                troyler
                                is there a way to increase the storage to add more apps, i have 64gb.
