    M5Dial TFT_eSPI pinout
    SOFTWARE
    5
    17
    15.0k
    • gordshG
      gordsh
      @ajb2k3 said in M5Dial TFT_eSPI pinout:
      M5
      Thank you.
        Hello @gordsh
        re TFT_eSPI : try adding the following define in Setup200_GC9A01.h
        #define TFT_BACKLIGHT_ON HIGH
        re GC9A01_demo : please find an M5Dial version here.
        • gordshG
          gordsh
          @felmue, thanks very much, This worked perfectly.
            mukul_100_ @gordsh
            @gordsh Hi ,
            did you get this working ?
            I am banging my head against the wall with this one right now ,
            I am trying to use EEZ Studio with M5dial and using platform.io (or arduino ide whichever works)
            also if you have the file of user_setup.h for GC9A01. kindly share
            Thank You
              mukul_100_ @mukul_100_
              @mukul_100_ Got this workking by using m5unified instead of tft_espi
              But i can get the touch to work
              as per what i read lvgl uses polling to get the touch coordinates using lv_timer_handler();
              but i dont understand how to implement M5Dial.Touch.getDetail(); to get the touch
              gordshG 2 Replies Last reply Reply Quote 0
              • gordshG
                gordsh @mukul_100_
                @mukul_100_ I did get this working, I am having a different issue now but I will send you a small demo program that I wrote using LVGL with touch.
                • gordshG
                  gordsh @mukul_100_
                  @mukul_100_ Here is a small demo of the M5Dial with touch and LVGL. Hope this helps and sorry for the delay.
                  M5DialLVGLTouchDemo.ino
                  M gordshG S 3 Replies Last reply Reply Quote 0
                    mukul_100_ @gordsh
                    @gordsh Oh great thanks a lot, I actually got it working,
                    and after seeing your code i tried to implement the button part with encoder but the dial seems to crash repeatedly because of it. For now that is not my focus so i will try it again later.
                    Also , do you have any idea how the implementation of encoder is eez studio is.
                    i understood that the group is to be made but didnt quite understand how to append/impelment the encoder events to it
                    If anyone has any idea or reference, Thank you in advance.
                    also this is the code for how i implemented the button press with encoder
                    // Encoder read function
                    void encoder_read(lv_indev_drv_t *drv, lv_indev_data_t *data) {
                        long newPosition = M5Dial.Encoder.read() / 4; // Normalize encoder position
                        if (newPosition != oldPosition) {
                            int encoderDiff = newPosition - oldPosition;
                            oldPosition = newPosition;
                            // React to encoder rotation
                            if (encoderDiff > 0) {
                                lv_group_focus_next(group);
                            } else if (encoderDiff < 0) {
                                lv_group_focus_prev(group);
                        // Check button press
                        if (M5Dial.BtnA.wasPressed()) {
                            data->state = LV_INDEV_STATE_PR;
                            Serial.println("M5.BtnA Pressed");
                        } else {
                            data->state = LV_INDEV_STATE_REL;
                    // Display flush function
                    void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) {
                        uint32_t width = (area->x2 - area->x1 + 1);
                        uint32_t height = (area->y2 - area->y1 + 1);
                        M5.Display.startWrite();
                        M5.Display.setAddrWindow(area->x1, area->y1, width, height);
                        M5.Display.pushPixels((uint16_t *)&color_p->full, width * height, true);
                        M5.Display.endWrite();
                        lv_disp_flush_ready(disp);
                        auto cfg = M5.config();
                        M5Dial.begin(cfg, true, false);
                        Serial.begin(115200);
                        // LVGL initialization
                        lv_init();
                        lv_disp_draw_buf_init(&drawBuffer, buffer, NULL, SCREEN_WIDTH * SCREEN_HEIGHT / 10);
                        static lv_disp_drv_t disp_drv;
                        lv_disp_drv_init(&disp_drv);
                        disp_drv.hor_res = SCREEN_WIDTH;
                        disp_drv.ver_res = SCREEN_HEIGHT;
                        disp_drv.flush_cb = my_disp_flush;
                        disp_drv.draw_buf = &drawBuffer;
                        lv_disp_drv_register(&disp_drv);
                        static lv_indev_drv_t encoder_drv;
                        lv_indev_drv_init(&encoder_drv);
                        encoder_drv.type = LV_INDEV_TYPE_ENCODER;
                        encoder_drv.read_cb = encoder_read;
                        encoder_indev = lv_indev_drv_register(&encoder_drv);
                        // Create a group and assign it to the encoder input device
                        group = lv_group_create();
                        lv_indev_set_group(encoder_indev, group);
                        // Create focusable widgets
                        lv_obj_t *btn1 = lv_btn_create(lv_scr_act());
                        lv_obj_align(btn1, LV_ALIGN_CENTER, -60, 0);
                        lv_obj_t *label1 = lv_label_create(btn1);
                        lv_label_set_text(label1, "Button 1");
                        lv_obj_t *btn2 = lv_btn_create(lv_scr_act());
                        lv_obj_align(btn2, LV_ALIGN_CENTER, 60, 0);
                        lv_obj_t *label2 = lv_label_create(btn2);
                        lv_label_set_text(label2, "Button 2");
                        lv_obj_t *btn3 = lv_btn_create(lv_scr_act());
                        lv_obj_align(btn3, LV_ALIGN_CENTER, 0, 50);
                        lv_obj_t *label3 = lv_label_create(btn3);
                        lv_label_set_text(label3, "Button 3");
                        // Add widgets to the group
                        lv_group_add_obj(group, btn1);
                        lv_group_add_obj(group, btn2);
                        lv_group_add_obj(group, btn3);
                    • gordshG
                      gordsh @gordsh
                      @gordsh thanks for sending, I actually don't know eez studio at all, I have never used it..
                        mukul_100_ @gordsh
                        @gordsh in your code, is the press function working successfully?
                        i am getting crashes for now, i am trying to use the button as a external button and not as a encoder button, the main problems seems to be init of button
                          SadE54 @gordsh
                          @gordsh Do you think with the lvgl m5dial setup , that Squareline Studio is usable ?
                          gordshG 1 Reply Last reply Reply Quote 0
                          • gordshG
                            gordsh @SadE54
                            @SadE54 I believe it is.
