    M5Dial TFT_eSPI pinout
    SOFTWARE
    5
    17
    15.0k
      Have you added the GC9A01 driver?
      • gordshG
        gordsh
        @ajb2k3 said in M5Dial TFT_eSPI pinout:
        GC9A01 driver
        Hmm, no I did not. Let me do some research and try to find the driver
        • gordshG
          gordsh
          Can any one get this simple GC9A01 test to run on the M5Dial
          • https://github.com/carlfriess/GC9A01_demo
          My goal is to have LVGL running on the M5Dial so I am working my way through the display issues at this time.
            This is the Micropython code I used to get a basic "Hello World" working.
            import os, sys, io
            import M5
            from M5 import *
            label0 = None
            def setup():
              global label0
              M5.begin()
              label0 = Widgets.Label("label", 50, 100, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
              label0.setCursor(x=50, y=100)
              label0.setText(str('Hello World'))
              label0.setVisible(True)
            def loop():
              global label0
              M5.update()
            if __name__ == '__main__':
              try:
                setup()
                while True:
                  loop()
                try:
                  print_error_msg(e)
                except ImportError:
                  print("please update to latest firmware”)
            • gordshG
              gordsh
              M5
              Thank you.
                Hello @gordsh
                re TFT_eSPI : try adding the following define in Setup200_GC9A01.h
                #define TFT_BACKLIGHT_ON HIGH
                re GC9A01_demo : please find an M5Dial version here.
                • gordshG
                  gordsh
                  @felmue, thanks very much, This worked perfectly.
                    mukul_100_ @gordsh
                    @gordsh Hi ,
                    did you get this working ?
                    I am banging my head against the wall with this one right now ,
                    I am trying to use EEZ Studio with M5dial and using platform.io (or arduino ide whichever works)
                    also if you have the file of user_setup.h for GC9A01. kindly share
                    Thank You
                      mukul_100_ @mukul_100_
                      @mukul_100_ Got this workking by using m5unified instead of tft_espi
                      But i can get the touch to work
                      as per what i read lvgl uses polling to get the touch coordinates using lv_timer_handler();
                      but i dont understand how to implement M5Dial.Touch.getDetail(); to get the touch
                      gordshG 2 Replies Last reply Reply Quote 0
                      • gordshG
                        gordsh @mukul_100_
                        @mukul_100_ I did get this working, I am having a different issue now but I will send you a small demo program that I wrote using LVGL with touch.
                        • gordshG
                          gordsh @mukul_100_
                          @mukul_100_ Here is a small demo of the M5Dial with touch and LVGL. Hope this helps and sorry for the delay.
                          M5DialLVGLTouchDemo.ino
                          M gordshG S 3 Replies Last reply Reply Quote 0
                            mukul_100_ @gordsh
                            @gordsh Oh great thanks a lot, I actually got it working,
                            and after seeing your code i tried to implement the button part with encoder but the dial seems to crash repeatedly because of it. For now that is not my focus so i will try it again later.
                            Also , do you have any idea how the implementation of encoder is eez studio is.
                            i understood that the group is to be made but didnt quite understand how to append/impelment the encoder events to it
                            If anyone has any idea or reference, Thank you in advance.
                            also this is the code for how i implemented the button press with encoder
                            // Encoder read function
                            void encoder_read(lv_indev_drv_t *drv, lv_indev_data_t *data) {
                                long newPosition = M5Dial.Encoder.read() / 4; // Normalize encoder position
                                if (newPosition != oldPosition) {
                                    int encoderDiff = newPosition - oldPosition;
                                    oldPosition = newPosition;
                                    // React to encoder rotation
                                    if (encoderDiff > 0) {
                                        lv_group_focus_next(group);
                                    } else if (encoderDiff < 0) {
                                        lv_group_focus_prev(group);
                                // Check button press
                                if (M5Dial.BtnA.wasPressed()) {
                                    data->state = LV_INDEV_STATE_PR;
                                    Serial.println("M5.BtnA Pressed");
                                } else {
                                    data->state = LV_INDEV_STATE_REL;
                            // Display flush function
                            void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) {
                                uint32_t width = (area->x2 - area->x1 + 1);
                                uint32_t height = (area->y2 - area->y1 + 1);
                                M5.Display.startWrite();
                                M5.Display.setAddrWindow(area->x1, area->y1, width, height);
                                M5.Display.pushPixels((uint16_t *)&color_p->full, width * height, true);
                                M5.Display.endWrite();
                                lv_disp_flush_ready(disp);
                                auto cfg = M5.config();
                                M5Dial.begin(cfg, true, false);
                                Serial.begin(115200);
                                // LVGL initialization
                                lv_init();
                                lv_disp_draw_buf_init(&drawBuffer, buffer, NULL, SCREEN_WIDTH * SCREEN_HEIGHT / 10);
                                static lv_disp_drv_t disp_drv;
                                lv_disp_drv_init(&disp_drv);
                                disp_drv.hor_res = SCREEN_WIDTH;
                                disp_drv.ver_res = SCREEN_HEIGHT;
                                disp_drv.flush_cb = my_disp_flush;
                                disp_drv.draw_buf = &drawBuffer;
                                lv_disp_drv_register(&disp_drv);
                                static lv_indev_drv_t encoder_drv;
                                lv_indev_drv_init(&encoder_drv);
                                encoder_drv.type = LV_INDEV_TYPE_ENCODER;
                                encoder_drv.read_cb = encoder_read;
                                encoder_indev = lv_indev_drv_register(&encoder_drv);
                                // Create a group and assign it to the encoder input device
                                group = lv_group_create();
                                lv_indev_set_group(encoder_indev, group);
                                // Create focusable widgets
                                lv_obj_t *btn1 = lv_btn_create(lv_scr_act());
                                lv_obj_align(btn1, LV_ALIGN_CENTER, -60, 0);
                                lv_obj_t *label1 = lv_label_create(btn1);
                                lv_label_set_text(label1, "Button 1");
                                lv_obj_t *btn2 = lv_btn_create(lv_scr_act());
                                lv_obj_align(btn2, LV_ALIGN_CENTER, 60, 0);
                                lv_obj_t *label2 = lv_label_create(btn2);
                                lv_label_set_text(label2, "Button 2");
                                lv_obj_t *btn3 = lv_btn_create(lv_scr_act());
                                lv_obj_align(btn3, LV_ALIGN_CENTER, 0, 50);
                                lv_obj_t *label3 = lv_label_create(btn3);
                                lv_label_set_text(label3, "Button 3");
                                // Add widgets to the group
                                lv_group_add_obj(group, btn1);
                                lv_group_add_obj(group, btn2);
                                lv_group_add_obj(group, btn3);
                            • gordshG
                              gordsh @gordsh
                              @gordsh thanks for sending, I actually don't know eez studio at all, I have never used it..
                                mukul_100_ @gordsh
                                @gordsh in your code, is the press function working successfully?
                                i am getting crashes for now, i am trying to use the button as a external button and not as a encoder button, the main problems seems to be init of button
                                  SadE54 @gordsh
                                  @gordsh Do you think with the lvgl m5dial setup , that Squareline Studio is usable ?
                                  gordshG 1 Reply Last reply Reply Quote 0
                                  • gordshG
                                    gordsh @SadE54
                                    @SadE54 I believe it is.
