    UIFlow 1.7.6
    Official Updates
    9
    20
    31.6k
      ajb2k3 @felmue
      @felmue said in UIFlow 1.7.6:
      Hello @shally1986
      same here. I think the reason for the green light blinking is that when M5Stack (Gray) is turned off it doesn't fully turn of the 5 V. (I measure about 2 V when turned off.)
      That said, I think GoPlus2 was designed for M5Stack (Gray, Fire, etc.) and not for M5Core2 since w/o electrical modification you'll loose external I2C on M5Core2.
      Am I missing something here, the GoPlus2 was designed for the core2's (hence the 2 designation) the Goplus was designed for the core/gray/go/fire.
      I haven't had time to check the Goplus2 as its connected to a robot and been busy with other projects.
        Hello @ajb2k3
        I don't know for sure for which core the GoPlus2 was designed for, but I think it was meant for M5Stack (Gray, Fire, etc.).
        All I can say (looking at the schematic) is that electrically it is not fully compatible with the M5Core2.
        Also, all Arduino examples I can find are for M5Stack (Gray, Fire, etc.) and none for M5Core2.
        And the GoPlus (first generation) is EOL.
        BTW: I don't think the '2' is because it is meant for M5Core2. It's simply the successor of the first GoPlus module. Which, if I am correct, is an unlucky (and confusing) naming.
          ajb2k3 @felmue
          @felmue I took it that it was for the core 2 as it has the different case shape and the longer Mbus header pins
          • m5stackM
            m5stack @Doswiadczalnik
            @doswiadczalnik now it fixed. you could remove the old firmware file then download again.
              8Servos hat intermittent response with 1.7.6
              • MatiM
                Mati
                @m5stack when we gonna see UiFlow with zigbee Init and COM ?
                • m5stackM
                  m5stack @ajb2k3
                  @ajb2k3 could you share your code here? it would helpful for us to debug it.
                  • m5stackM
                    m5stack @Mati
                    @mati It is in our support plan and will be supported in future updates. so maybe after a few weeks, it will be supported.
                    MatiM 1 Reply Last reply Reply Quote 0
                    • MatiM
                      Mati @m5stack
                      @m5stack thx, maybe some day uiflow will be able to support new HW at rls day ;)
                      • P
                        plusulli
                        I cannot get a QRCODE for the Cloud with the UNITCAM examples.
                        • K
                          kmart93179
                          I use weight unit for port A and the GOPlus2 Base at the same time. it seem like it cant work together,When i trigger the server motor ,my weight unit dont work anymore,the label keep show 0 ,i think maybe is I2C issue ,any ideas?
                          thx
                          skyler
                          • K
                            kmart93179
                            • m5stackM
                              m5stack @kmart93179
                              @kmart93179 weight unit is not used the I2C protocol of course they not compatible.
