    UIFlow 1.7.6
    Official Updates
    9
    20
    31.6k
      Hello @shally1986
      same here. I think the reason for the green light blinking is that when M5Stack (Gray) is turned off it doesn't fully turn of the 5 V. (I measure about 2 V when turned off.)
      That said, I think GoPlus2 was designed for M5Stack (Gray, Fire, etc.) and not for M5Core2 since w/o electrical modification you'll loose external I2C on M5Core2.
        ajb2k3 @felmue
        @felmue said in UIFlow 1.7.6:
        Hello @shally1986
        Am I missing something here, the GoPlus2 was designed for the core2's (hence the 2 designation) the Goplus was designed for the core/gray/go/fire.
        I haven't had time to check the Goplus2 as its connected to a robot and been busy with other projects.
          Hello @ajb2k3
          I don't know for sure for which core the GoPlus2 was designed for, but I think it was meant for M5Stack (Gray, Fire, etc.).
          All I can say (looking at the schematic) is that electrically it is not fully compatible with the M5Core2.
          Also, all Arduino examples I can find are for M5Stack (Gray, Fire, etc.) and none for M5Core2.
          And the GoPlus (first generation) is EOL.
          BTW: I don't think the '2' is because it is meant for M5Core2. It's simply the successor of the first GoPlus module. Which, if I am correct, is an unlucky (and confusing) naming.
            ajb2k3 @felmue
            @felmue I took it that it was for the core 2 as it has the different case shape and the longer Mbus header pins
            • m5stackM
              m5stack @Doswiadczalnik
              @doswiadczalnik now it fixed. you could remove the old firmware file then download again.
                8Servos hat intermittent response with 1.7.6
                • MatiM
                  Mati
                  @m5stack when we gonna see UiFlow with zigbee Init and COM ?
                  • m5stackM
                    m5stack @ajb2k3
                    @ajb2k3 could you share your code here? it would helpful for us to debug it.
                    • m5stackM
                      m5stack @Mati
                      @mati It is in our support plan and will be supported in future updates. so maybe after a few weeks, it will be supported.
                      MatiM 1 Reply Last reply Reply Quote 0
                      • MatiM
                        Mati @m5stack
                        @m5stack thx, maybe some day uiflow will be able to support new HW at rls day ;)
                        • P
                          plusulli
                          I cannot get a QRCODE for the Cloud with the UNITCAM examples.
                          • K
                            kmart93179
                            I use weight unit for port A and the GOPlus2 Base at the same time. it seem like it cant work together,When i trigger the server motor ,my weight unit dont work anymore,the label keep show 0 ,i think maybe is I2C issue ,any ideas?
                            thx
                            skyler
                            • K
                              kmart93179
                              • m5stackM
                                m5stack @kmart93179
                                @kmart93179 weight unit is not used the I2C protocol of course they not compatible.
