    M5Core2 library fork that supports multi-touch and provides Arduino-style virtual buttons [update: and gestures and events] [update2: MERGED !]
    55 Posts 5 Posters 266.8k Views 3 Watching
    • vkichlineV Offline
      vkichline
      Rop, I've opened issues on your fork, and will continue to do so as I work through the library.
      I wrote a goal-based UI evaluation tool for Touch and posted it here: https://github.com/vkichline/TouchGoal . Please give it a try!
      It asks you to accomplish 16 Touch tasks in random order and keeps score, telling you what you missed at the end. You have up to 8 seconds for each task, but they end as soon as you successfully complete them, so it's pretty fast.
      I had written some tools to spew event names, but didn't get a feel for how Touch worked in real life; this test tool provides that feedback.
      I expected to have issues with gestures based on my serial spewing tests, but they seem quite solid. However, I usually fail to get all the double taps. Does double-tapping work better for you?
      Age and fast-twitch motor neurons have a lot of sway over double-click success, it may be a bit too hot for me. Can the delay be adjusted?
      If you can breeze through this test w/o failures, that would tell you the UI is doing what you expect it to do.
      • RopR Offline
        Rop @vkichline
        @vkichline Thanks!! Shouldn't have used NONE, neither here nor in ezTime. Its now NODRAW (again) in this library. i like TouchGoal. Fixed all the issues, I think. The documentation has been completely overhauled.
        • RopR Offline
          Rop @vkichline
          @vkichline In fact, shall we include TouchGoal as an example with the M5Core2 library?
            vkichline
            You're welcome to include it! Some additional tests for what shouldn't happen and a few comments about the best way to detect things would make it more valuable.
            It's always nice to have a comprehensive suite to walk through after making 'improvements'. I could see TouchGoal being useful for testing subclasses of buttons, zones, etc.
            When you think about it being used for testing subclasses, are there any additions you can think of? It's mostly positive testing now, few negative checks. (For example, you should not get this event before that event in this case...)
              vkichline
              Tried your changes and I can successfully double-tap every time now. Excellent!
              I will add long presses to TouchGoal as soon as I figure them out. But today's my anniversary, so until later!
              • RopR Offline
                Rop
                I think it's a wrap...
                That is: on something this size there will always be more work to do and corners that could be even cleaner. But i think it works, does the job, is well-documented and at the very least doesn't break anything else.
                So please give it a good test and tell me what y'all think, and then I'll make the PRs for M5Core2 (with M5Touch) and M5Stack (just m5Button).
                @vkichline By all means wrap up TouchGoal so it can be included.
                Everyone: please give the documentation a read and maybe write a tiny thing yourself to see if it works like you would expect... I'd love some more really basic simple examples if you can find the time...
                  vkichline
                  I've updated TouchGoal with long touches and better syntax. It's ready to go. BTW, I consistently get 100% scores now, so Touch is doing exactly what I want it to do.
                  I've added another testing program you may be interested in as well: TouchView.
                  It displays events to the screen as well as to the serial port. I like to test in an easy chair.
                  The A button turns E_MOVE an and off, B enables/disable long touches, and C toggles key repeat.
                  A good way to look for unexpected events. Looks clean to me.
                  I did report one bug I'd call a show stopper; #22. (I added a lot of issues, so it could get lost in the soup):
                  • Run events_buttons_gestures_rotation
                  • Double-tap top-left button. Turns blue. Good.
                  • Swipe up. Display inverts. Good.
                  • Double-tap button named "top-left" (now at bottom-right.) Button named "bottom-left" (in top-right position) becomes blue. Error.
                  Also, the file M5Touch.h didn't get updated; it has at least one example program (the first example in the top level file) which does not compile. I opened detailed issues at https://github.com/ropg/M5Core2/issues. It looks like a lot but most are typos.
                  I know I'm a noisy gong, always with the nits and quibbles, but on the whole this is excellent! I'm surprised at how reliably the gestures work; I took a stab at that myself and it was far from trivial. The two-finger support and rotation really go above and beyond as well! A huge leap forward for the Core2 platform.
                  • B Offline
                    brownb2
                    • B Offline
                      brownb2
                      @Rop I've just started some work porting some old Core 1 M5Stack code to the Core 2 API and found that the 3 bottom buttons don't work quite in the same way.
                      For instance this:
                      if (M5.BtnA.isPressed() && M5.BtnC.isPressed()) {
                      // do something
                      doesn't work on the Core 2 despite the multi touch. It only registers the first button to be pressed rather than both.
                      Is this something you could fix or provide a hint as to what I need to look at to hack it myself?
                      • B Offline
                        brownb2
                        For anybody else looking at fixing the issue with multiple simultaneous button presses it seems it can't be done.
                        Having dived into the M5Core2 source the events generated for two button presses, e.g. A & C, are press for A and move for A.
                        This looked like a deeper bug (since the second should have been identified as C), so going further in I found that an else branch wasn't refreshing the currently identified touched button on second press (C) in the method "doEvents" in touch.cpp (it doesn't help the code isn't documented, isn't single responsibility and has an arrow antipattern too).
                        Fixing that bug, so the correct button is refreshed, showed that two events together did not produce presses for A & C but instead (I assume - I'm fed up at this point) the hardware averages the presses' coordinates and declares it's button B(!) that is pressed.
                        If you have old Core 1 code you're porting that uses two simultaneous button presses I'd suggest changing the code to double taps of a single button instead which is the workaround I'm about to use - to remain consistent this behaviour is both on Core 1 and Core 2
                        More formally, I should have read the file header in touch.h earlier:
                        the M5Stack Core2 touch display is only
                        multi-touch in one dimension. What that means is that it can detect two
                        separate touches only if they occur on different vertical positions.
                        This has to do with the way the touch screen is wired, it's not
                        something that can be changed in software. So you will only ever see
                        two points if they do not occur side-by-side. Touches that do happen
                        side-by-side blend into one touch that is detected somewhere between
                        the actual touches.
