    drawJpgFile / drawBmpFile
    30 Posts 4 Posters 147.1k Views 2 Watching
      Richard
      m5stack from m5stack store
        Richard
          Calin
          Here is the test using your code (with small modifications and relevant comments)
          and standard m5Stack library from PlatformIO:
          And here is the result:
            Richard
            fine, but does not work on ide arduino.
            can you send me your code in espi setup?
              Richard
              do you have tested my with arduino ide?
              thank you
                Richard
                i have install PlatformIO and load my projet:
                Wrote 230992 bytes (123957 compressed) at 0x00010000 in 11.0 seconds (effective 168.6 kbit/s)...
                Hash of data verified.
                Leaving...
                Hard resetting via RTS pin...
                ====================================================== [SUCCESS] Took 23.68 seconds =======================================
                I still have the problem!
                hardware problem?
                I
                  Agreed, Following this myself and just get a blank screen with the image not loaded. This is my image 0_1529644400361_logo.jpg
                    Calin @Richard
                    @richard No. i didn't tested with arduino "ide". I uninstalled that from my PC because is mostly useless...
                    I use Visual Studio, Eclipse or PlatformIO.
                    I uploaded the PlatformIO project for your code to github: https://github.com/botofancalin/M5StackJpgtest
                    The M5Stack library is already installed local into project.
                    All you have to do is to download the repository and compile the code.
                      ajb2k3 @Calin
                      @calin 在 drawJpgFile / drawBmpFile 中说:
                      Maybe a stupid question (or two) but I'm going to ask anyway.
                      Is there a hardware limitation for this i.e. is there a card size limit and a formatting requirement?
                      Is there a specific image limitation for the image?
                        Richard
                        I use Visual Studio too.
                        i have just tested your programm and i still have the problem.
                        I think it's a hardware problem.
                        I'm waiting for another device
                        Thank you.
                          Calin @Richard
                          @ajb2k3 在 drawJpgFile / drawBmpFile 中说:
                          I think there is no limitation on card size.
                          There might be a limitation on card read/write speed and that depend on the sdcard manufacturer and model.
                          As i know, the cards formatted as FAT32 are preffered.
                          @richard 在 drawJpgFile / drawBmpFile 中说:
                          Thank you.
                          That problem can be caused by the ILI9341 controller from the TFT.
                          If that is the case, the only solution is a replacement.
                            Richard
                            I use a SD 4mo FAT32
                              Richard
                              and also
                              I tested with a 32mo
                                I have a 32gig Class 10 sdhc formatted as fat32 MBT.
                                How do I tell if I have the ILI9341?
                                  Calin @ajb2k3
                                  @ajb2k3 ILI9341 is the LCD driver used by the M5Stack TFT display: https://cdn-shop.adafruit.com/datasheets/ILI9341.pdf
                                    Ok, failed to get it to work with the jpgdraw script but if I convert to array it works, But!!!!!!
                                    I had to reduce the image to a 256bit Indexed image!
                                      Richard
                                      I tested my programm and my file jpg (sd 4go) with IDE Arduino 1.8.5 on another M5Stack .
                                      It works very well.
                                      The first M5stack doesn't work propely.
                                      I hope the M5stack store will change it.
                                        Richard
                                          Richard
                                          Thank you Calin!
