    drawJpgFile / drawBmpFile
    30 Posts 4 Posters 147.1k Views 2 Watching
      Richard
      my jpg 320*240 on sd
      i have m5stack core 0.2.0
        Calin
        That problem is caused by SPI frequency.
        Try to lower the SPI frequency from TFT driver then it should work just fine.
        In most cases, 27Mhz SPI work just fine with most TFT's.
          Richard
          thanks, but I don't find this driver
            Richard @Richard
            @richard
            I tried all the tft spi sd frequencies and I still have the problem!
            an idea?
              Calin @Richard
              @richard The TFT SPI frequency is defined on In_eSPI_Setup.h file from M5Stack library at line 202: https://github.com/m5stack/M5Stack/blob/1772fd68743a7728e64ab6d24b931e1183599981/src/utility/In_eSPI_Setup.h#L202
              Try to set it to 27000000
              The SD SPI freqency can be different than TFT SPI frequency, since SD is on a different SPI bus.
                Richard @Calin
                @calin
                thanks,
                I tried but I still have the problem!
                no idea
                  Calin
                  Please share your code so i can check and see what's the problem there.
                    Richard
                    my code
                    #include <M5Stack.h>
                    void setup(void) {
                    M5.Lcd.setBrightness(200);
                    M5.Lcd.drawJpgFile(SD, "/corto.jpg"); // Load background from SD
                    //M5.Lcd.drawJpgFile(SD, "/corto_1.jpg", 0, 20, 300, 200);
                    // M5.Lcd.drawJpgFile(fs::FS &fs, const char *path, uint16_t x, uint16_t y, uint16_t maxWidth, uint16_t maxHeight, uint16_t offX, uint16_t offY, jpeg_div_t scale);
                    M5.update();
                    delay(1000);
                    Thank you
                      Richard
                        Richard
                        m5stack from m5stack store
                          Richard
                            Calin
                            Here is the test using your code (with small modifications and relevant comments)
                            and standard m5Stack library from PlatformIO:
                            And here is the result:
                              Richard
                              fine, but does not work on ide arduino.
                              can you send me your code in espi setup?
                                Richard
                                do you have tested my with arduino ide?
                                thank you
                                  Richard
                                  i have install PlatformIO and load my projet:
                                  Wrote 230992 bytes (123957 compressed) at 0x00010000 in 11.0 seconds (effective 168.6 kbit/s)...
                                  Hash of data verified.
                                  Leaving...
                                  Hard resetting via RTS pin...
                                  ====================================================== [SUCCESS] Took 23.68 seconds =======================================
                                  hardware problem?
                                  I
                                    Agreed, Following this myself and just get a blank screen with the image not loaded. This is my image 0_1529644400361_logo.jpg
                                      Calin @Richard
                                      @richard No. i didn't tested with arduino "ide". I uninstalled that from my PC because is mostly useless...
                                      I use Visual Studio, Eclipse or PlatformIO.
                                      I uploaded the PlatformIO project for your code to github: https://github.com/botofancalin/M5StackJpgtest
                                      The M5Stack library is already installed local into project.
                                      All you have to do is to download the repository and compile the code.
                                        ajb2k3 @Calin
                                        @calin 在 drawJpgFile / drawBmpFile 中说:
                                        Maybe a stupid question (or two) but I'm going to ask anyway.
                                        Is there a hardware limitation for this i.e. is there a card size limit and a formatting requirement?
                                        Is there a specific image limitation for the image?
                                          Richard
                                          I use Visual Studio too.
                                          i have just tested your programm and i still have the problem.
                                          I think it's a hardware problem.
                                          I'm waiting for another device
                                          Thank you.
                                            Calin @Richard
                                            @ajb2k3 在 drawJpgFile / drawBmpFile 中说:
                                            I think there is no limitation on card size.
                                            There might be a limitation on card read/write speed and that depend on the sdcard manufacturer and model.
                                            As i know, the cards formatted as FAT32 are preffered.
                                            @richard 在 drawJpgFile / drawBmpFile 中说:
                                            Thank you.
                                            That problem can be caused by the ILI9341 controller from the TFT.
                                            If that is the case, the only solution is a replacement.
