    PROJECTS
    22
    95
    714.4k
    • B
      bobolink
      I really like M5ez so I gave it its own core. Justified it by saying that’s real MVC architecture! Real Computer Science stuff.
      GLOBAL INFO
      core 0 is the communications processor.
      Uses the ESP-NOW protocol
      on the 2.4 GHz radio
      This process runs as a task created
      on core 1
      core 1 is the UI processor.
      Maintains the M5Stack M5ez LCD menu
      Runs Arduino setup() and loop()
      Use RTOS semaphores when accessing the global vars to/from the local versions.
        macle
        Is there a chance to change font (or size) of ez.header ?
        Regards, M
          mawg
          Looks great! Does it play well with PlatformIO ?
          • m5stackM
            Great Job
              @Rop is M5EZ supporting the Stick C?
              I have had a query from the Facebook group.
              • RopR
                Rop
                No it does not: it only works on the 3-Button M5Stack devices.
                  ajb2k3 @Rop
                  @rop Any intention of a stick version?
                  • asalazaroA
                    asalazaro @BrianR
                    @brianr @rop Hey guys, thanks a lot for this very elegant solution, I´m using the ezMenu library in a program where I had installed Blynk working very well but everytime when I activated the ezMenu with mainmenu.run(); my Blynk app was very unstable, with the trick of ez.addEvent(run_Blynk) in the setup() function now is working very well, thanks for the help
                    • H
                      hobo
                      great project.
                      It is possible to use the face encoder for up, down and enter?
                      if yes, you have an example?
                      this will be great
                      • H
                        hobo
                        • G
                          GSAL
                          It is great using the M5EZ!
                          But I want / need to give my Core a static IP address. Is there an easy way to alter the Wifi settings menu and add the option of adding static ip? Maybe In such a way it is stored in the preferences?
                          kr, G
                          • K
                            kilam
                            I wanted to know if there is a way to use faces keyboard in the menus (i.e. I have the calculator keyboard and instead of using the three buttons to go up and down and select, I want to use the keys on the face, for example for selecting first line I will type on the key '1' and so on).
                            and if it is possible, can you give me an example of code using it.
                            • A
                              AndyT
                              How do i get the characters for my region such as the pound sign £ ?
