    2. staberas
    S
    • Continue chat with staberas
    • Start new chat with staberas
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Posts made by staberas
    • RE: Any updates on the mpu6886?
      @bryam
      The code above is for the maixpy (micropython) not arduino
      posted in M5Stick V
      S
      staberas
    • RE: ImageWriter.add_frame(img) system crash
      Hi, in order to help you , we need to see the code
      posted in M5Stick V
      S
      staberas
    • RE: Use with a standard USB camera instead?
      Not possible, i had problems with rasp pi since the firmware/drivers used on those cameras are finicky
      posted in M5Stick V
      S
      staberas
    • RE: M5Stick-V microphono
      uhm, the mic has a design flow
      https://twitter.com/M5Stack/status/1164753358101463044
      1. M5StickV will not have Microphone function, which doesn't affect the normal usage;
      2. For customers who do need this function, pls contact your purchased channel for after service, till Sep. 30;
      3. M5StickV+ will be released end of 2019, adding Wifi and Microphone function.
      posted in M5Stick V
      S
      staberas
    • RE: m5Stack basic. Wrong colors.
      @borisu
      Please provide the code you upload
      posted in Cores
      S
      staberas
      done, used party code from anoken who sourced it from the arduino version , i clean up and updated it
      import image
      import lcd
      import sensor
      import sys
      import time
      import utime
      from board import board_info
      import KPU as kpu
      from Maix import GPIO
      from fpioa_manager import *
      from pmu import axp192
      from machine import I2C
      #pmu = axp192() - breaks IMU data -
      #pmu.enablePMICSleepMode(True) - breaks IMU data -
      i2c = I2C(I2C.I2C0, freq=400000, scl=28, sda=29)
      #devices = i2c.scan()
      lcd.init()
      # IMU6866 define
      MPU6886_ADDRESS=0x68
      MPU6886_WHOAMI=0x75
      MPU6886_ACCEL_INTEL_CTRL=0x69
      MPU6886_SMPLRT_DIV=0x19
      MPU6886_INT_PIN_CFG=0x37
      MPU6886_INT_ENABLE=0x38
      MPU6886_ACCEL_XOUT_H=0x3B
      MPU6886_TEMP_OUT_H=0x41
      MPU6886_GYRO_XOUT_H=0x43
      MPU6886_USER_CTRL= 0x6A
      MPU6886_PWR_MGMT_1=0x6B
      MPU6886_PWR_MGMT_2=0x6C
      MPU6886_CONFIG=0x1A
      MPU6886_GYRO_CONFIG=0x1B
      MPU6886_ACCEL_CONFIG=0x1C
      MPU6886_ACCEL_CONFIG2=0x1D
      MPU6886_FIFO_EN=0x23
      # IMU6866 Initialize
      def write_i2c(address, value):
      	i2c.writeto_mem(MPU6886_ADDRESS, address, bytearray([value]))
      	time.sleep_ms(10)
      write_i2c(MPU6886_PWR_MGMT_1, 0x00)
      write_i2c(MPU6886_PWR_MGMT_1, 0x01<<7)
      write_i2c(MPU6886_PWR_MGMT_1,0x01<<0)
      write_i2c(MPU6886_ACCEL_CONFIG,0x10)
      write_i2c(MPU6886_GYRO_CONFIG,0x18)
      write_i2c(MPU6886_CONFIG,0x01)
      write_i2c(MPU6886_SMPLRT_DIV,0x05)
      write_i2c(MPU6886_INT_ENABLE,0x00)
      write_i2c(MPU6886_ACCEL_CONFIG2,0x00)
      write_i2c(MPU6886_USER_CTRL,0x00)
      write_i2c(MPU6886_FIFO_EN,0x00)
      write_i2c(MPU6886_INT_PIN_CFG,0x22)
      write_i2c(MPU6886_INT_ENABLE,0x01)
      # Read IMU6866 and Scaling
      def read_imu():
      	aRes=255/4096/2
      	gRes = 2000.0/32768.0
      	offset=128
      	accel = i2c.readfrom_mem(MPU6886_ADDRESS, MPU6886_ACCEL_XOUT_H, 6)
      	accel_x = (accel[0]<<8|accel[1])
      	accel_y = (accel[2]<<8|accel[3])
      	accel_z = (accel[4]<<8|accel[5])
      	if accel_x>32768:
      		accel_x=accel_x-65536
      	if accel_y>32768:
      		accel_y=accel_y-65536
      	if accel_z>32768:
      		accel_z=accel_z-65536
      	ax=int(accel_x*aRes+offset)
      	if ax<0: ax=0
      	if ax>255: ax=255
      	ay=int(accel_y*aRes+offset)
      	if ay<0: ay=0
      	if ay>255: ay=255
      	az=int(accel_z*aRes+offset)
      	if az<0: az=0
      	if az>255: az=255
      	accel_array = [ax,ay,az]
      	gyro = i2c.readfrom_mem(MPU6886_ADDRESS, MPU6886_GYRO_XOUT_H, 6)
      	gyro_x = (gyro[0]<<8|gyro[1])
      	gyro_y = (gyro[2]<<8|gyro[3])
      	gyro_z = (gyro[4]<<8|gyro[5])
      	if gyro_x>32768:
      		gyro_x=gyro_x-65536
      	if gyro_y>32768:
      		gyro_y=gyro_y-65536
      	if gyro_z>32768:
      		gyro_z=gyro_z-65536
      	gx=int(gyro_x*gRes+offset)
      	if gx<0: gx=0
      	if gx>255: gx=255
      	gy=int(gyro_y*gRes+offset)
      	if gy<0: gy=0
      	if gy>255: gy=255
      	gz=int(gyro_x*gRes+offset)
      	if gz<0: gz=0
      	if gz>255: gz=255
      	gyro_array = [gx,gy,gz]
      	return accel_array, gyro_array
      lcd.rotation(2)
      task = kpu.load("/sd/7118109ae3ea570e_mbnet10_quant.kmodel")#change model
      labels=["seadog","Borbya","mermaid","Villo"] #change names.
      sensor.reset()
      sensor.set_pixformat(sensor.RGB565)
      sensor.set_framesize(sensor.QVGA)
      sensor.set_windowing((224, 224))
      sensor.run(1)
      lcd.clear()
      while(True):
      	accel_array,gyro_array = read_imu()
      	img = sensor.snapshot()
      	fmap = kpu.forward(task,img)
      	plist=fmap[:]
      	pmax=max(plist)
      	#lcd.draw_string(40, 20, str(accel_array))
      	#lcd.draw_string(10, 40, str(gyro_array))
      	max_index=plist.index(pmax)
      	if pmax > 0.95:
      		#lcd.draw_string(40, 60, "Accu:%.2f Type:%s"%(pmax, labels[max_index].strip()))  #20-59,130-136,55-30 [side view] 100-130,130-136,9-20 [top view]
              #the values are from 0 to 255
      		if accel_array[0] > 20 and accel_array[0] < 59 and accel_array[1] > 130 and accel_array[1] < 136 and accel_array[2] > 30 and accel_array[2] < 55:
      			img.draw_image(image.Image("/sd/view2.jpg"), 50, 50,x_scale=0.5,y_scale=0.5,mask=image.Image("/sd/view2t.jpg"))
      		if accel_array[0] > 60  and accel_array[0] < 130 and accel_array[1] > 130  and accel_array[1] < 137 and accel_array[2] > 8 and accel_array[2] < 20:
      			img.draw_image(image.Image("/sd/view1.jpg"), 50, 50,x_scale=0.5,y_scale=0.5,mask=image.Image("/sd/view1t.jpg"))
      	a = lcd.display(img)
      a = kpu.deinit(task)
      sys.exit()
      posted in M5Stick V
      S
      staberas
    • RE: M5StickV Firmware_1017 Upgrade
      im not sure i understand, can u provide an example ?
      EDIT: it works now i have to comment out those two:
      #pmu = axp192()
      when added they the IMU locks up
      posted in Official Updates
      S
      staberas
      new bug:
      "pmu import axp192" interferes when i try to get gyro/accel data from the MPU6886
      S
      staberas
    • RE: M5stack V uart communication
      https://m5stack.hackster.io/anoken2017/cheering-watch-of-m5stickc-v-34f0cc
      Near the end , tell us if it helps
      posted in M5Stick V
      S
      staberas
      @xeon sorry for resurrecting old post, i had the same problem, i currently close getting data from the IMU
      posted in M5Stick V
      S
      staberas
    • RE: Most of img.draw_string() parameters are not usable
      Hey
      While those parameters exist on the vanilla micropython (openmv), StickV uses a modified version of micropython (that comes with the firmware) if you need to do you have either 1. work around it (flip image instead of text ) or 2. compile your own firmware and upload it on the stick
      btw here are the values you can use on the stickV : https://maixpy.sipeed.com/en/libs/machine_vision/image.html#imagedrawstringx-y-text-color-scale1-xspacing0-yspacing0-monospacetrue
      posted in M5Stick V
      S
      staberas
    • Object recognition Questions
      I just generated a model using v-training , then tried to use yolo instead of fmap=kpu.forward(task,img) since i like to know the position of the object
      but the script stops working.. any help?
      posted in M5Stick V
      S
      staberas
    • RE: M5StickV dimensions
      4,8 X 2,5 X 2,3 cm
      Cheers
      posted in M5Stick V
      S
      staberas
    • RE: More info of the grove I2C connector
      @ajb2k3
      @M5STACK
      posted in M5Stick V
      S
      staberas
      @ajb2k3
      dunno, i just started testing it, my first test was to find the Voltage output and couldnt find it then tried all the methods above, among others flashing the latest firmware, unless the grove port is disable via software the port could have been dead from factory
      posted in M5Stick V
      S
      staberas
      yelp mine grove port is dead, tested multiple times with a i2c IPS display and a i2c scanner on Maixpy only get 2 devices and not a 3rd [0x34 & 0x68] also not getting any voltage output and also tested with a different power source on the IPS display but still not getting detected, this just sucks cause i had plans :(
      posted in M5Stick V
      S
      staberas
    • RE: M5StickV link/Info dump.
      @ajb2k3
      yes, cant seem to find info on it
      EDIT: i started testing the pins and i cant detect a voltage output
      posted in M5Stick V
      S
      staberas
      @ajb2k3
      4pin expansion PH2.0-4
      posted in M5Stick V
      S
      staberas
      Can anyone point me on how you use the expansion slot?
      posted in M5Stick V
      S
      staberas
    • RE: M5StickV Firmware_1022_beta Upgrade
      @thrasher
      i also did for me because maix editor fixes the whitespacing before uploading, if you edited the file in text mode like me you probable added some wrong whitespace character without knowing
      S
      staberas
