@ajb2k3 Thanks, it does work with 1.3.5 beta!
Best posts made by maechler
Latest posts made by maechler
RE: Connect units to PbHUBposted in Units
I ended up copy pasting the method from the
Lightunit with some slight adjustments:def pbhubAnalogRead(pbhub, pbhub_address): data = 0 max_val = 30 min_val = 750 for i in range(0, 10): newdata = 750 - pbhub.analogRead(pbhub_address) data += newdata if newdata > max_val: max_val = newdata if newdata < min_val: min_val = newdata data -= (max_val + min_val) data >>= 3 return round(max(1024 * data / 750, 0), 2) pbhub = unit.get(unit.PBHUB, unit.PORTA) light = pbhubAnalogRead(pbhub, 0x01)The magic number
min_valI got by pressing my finger on the light sensor (blocking all the light from entering) and reading the analog value. The value750seems to be the minimum value the light sensor would emit. The numbermax_valI got by pointing a strong light at the sensor, it seems to be the maximum value the sensor emits. The min max values are mixed up because it measures the resistance and decreasing resistance means increasing light intensity. Using this method I get values that are somewhat similar to what I get by connecting theLightunit toPortBdirectly.If anyone knows how this should be done properly, please let me know!
RE: How can I start my micro python program at resetposted in Micropython
I placed my stuff into the /apps folder, e.g. /apps/demo.py. On startup you can then press the button in the middle to enter the app list, choose your app demo and from there on it will be started automatically when you reboot.
@ws1088 Thanks for the clarification!
Do you say that the value I get withpbhub.analogRead(0x00)should be plugged in fornewdatainLight.analogValue?
I would have placed it where the Light unit callsself.adc.readraw().
Do I also have to callpbhub.analogRead(0x00)10 times in a loop, as the Light unit does?@ajb2k3 Yes, kind of. I have tested what the Light unit does for increasing values of
self.adc.readraw()it will output decreasing values. This inversion is missing when reading directly fromPbHUB.class Light: @staticmethod def analogValue(value): data = 0 max = 0 min = 4096 for i in range(0, 10): newdata = 4095 - value data += newdata if newdata > max: max = newdata if newdata < min: min = newdata data -= (max + min) data >>= 3 return round(1024 * data / 4095, 2) print(400, Light.analogValue(400)) # 400 923.98 print(500, Light.analogValue(500)) # 500 898.97 print(600, Light.analogValue(600)) # 600 873.96 print(700, Light.analogValue(700)) # 700 848.96 print(800, Light.analogValue(800)) # 800 823.95 print(900, Light.analogValue(900)) # 900 798.95 -
@lukasmaximus @ajb2k3 Thanks for your support! Although the video does not really answer my question.
I am able to read values from the PbHUB like this:
pbhub = unit.get(unit.PBHUB, unit.PORTA) earth = pbhub.analogRead(0x00) light = pbhub.analogRead(0x01)The problem is, that these values seem to be wrong. The lux value increases when it gets darker, similarly the earth unit says the earth gets dryer when it actually gets wetter. I think the problem is, that reading directly from
PbHUB, the logic from theLIGHT.analogValuefunction is missing:class Light: @property def analogValue(self): data = 0 max = 0 min = 4096 for i in range(0, 10): newdata = 4095 - self.adc.readraw() data += newdata if newdata > max: max = newdata if newdata < min: min = newdata data -= (max + min) data >>= 3 return round(1024 * data / 4095, 2)This function seems to transform the data in a way that is missing when reading the value directly from
PbHUB. My question is whether I do have to copy paste this logic or whether there is some way to reuse theLIGHTunit withPbHUB?I would like to be able to do something like this:
pbhub = unit.get(unit.PBHUB, unit.PORTA) earth = unit.get(unit.EARTH, pbhub.HUB0) # Not M5Stack API yet light = unit.get(unit.LIGHT, pbhub.HUB1) # Not M5Stack API yet # This should read the value correctly, using the `LIGHT.analogValue` logic print(earth.analogValue()) print(light.analogValue()) -
I am trying to connect a
LIGHTand anEARTHunit to thePbHUB. I connected thePbHUBtoPortA, theEARTHsensor toHub 0and theLIGHTsensor toHub 1.
My code looks like this:
pbhub = unit.get(unit.PBHUB, unit.PORTA) earth = pbhub.analogRead(0x00) light = pbhub.analogRead(0x01)I am able to read values from both sensors, however with strange behaviours. E.g. the lux value increases when it gets darker and vice versa. I guess the problem is, that I am lacking the logic of the
analogReadfunction in theLIGHTandEARTHunits:
https://github.com/m5stack/UIFlow-Code/blob/a0dbef98fe29323d6b1837b479764fdab50c3836/units/_light.py
https://github.com/m5stack/UIFlow-Code/blob/a0dbef98fe29323d6b1837b479764fdab50c3836/units/_earth.pyHowever I do not see how I would have to connect this unit correctly to the
PbHUB. Do I have to copy paste theanalogReadlogic or is there another way to connect these units?
@ajb2k3 Do you know how this should be handled? -
RE: PaHub Access cracked.posted in Units
@ajb2k3 I am using a regular M5Stack Core. So which version of UIFlow should I be using?
@lukasmaximus and @ajb2k3 Thank you very much for your answers!
I am working with Visual Studio Code and UIFlow-v1.3.2. But I use flow.m5stack.com to look up how to connect the sensors. I was confused because PaHub is greyed out there:
Thanks for showing how to select the PaHub, however it does still not work for me. Even with the simplest possible example in UI Flow I get the following error: 'module' object has no attribute 'PAHUB0'
from m5stack import *
from m5ui import *
from uiflow import *
import unitsetScreenColor(0x000000)
env1 = unit.get(unit.ENV, unit.PAHUB0)If I connect the same unit to unit.PORTA everything works fine. I would like to be able to connect EARTH, ENV and LIGHT units using the PaHub. Is it possible that not all units are supported yet?
E.g. for the EARTH unit I can not select PaHub using the drop down you showed.Thanks for your help!
Thanks for sharing! Do you also have an example on how to connect multiple sensors to the PaHub and read values from them?
