    2. jollawat
    J
    • Continue chat with jollawat
    • Start new chat with jollawat
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Save
    Saving
    jollawat
    @jollawat
    0
    Reputation
    6
    946
    Profile views
    0
    Followers
    0
    Following
    Joined Last Online
    jollawat Follow
    Posts made by jollawat
    • RE: M5 LAN Base with Core2 have no function on UIFlow
      @felmue Many thanks Felmue previously I'm use other F/W after use 1.9.8 it back to function.
      posted in UIFlow
      J
      jollawat
      @felmue It's works with machine type client?
      posted in UIFlow
      J
      jollawat
    • M5 LAN Base with Core2 have no function on UIFlow
      I tried to program by UIFlow when connect Core2 + LAN Base but seens it's not initialize as uasual, when use same code with Core Basic + Lan Base also function.
      Error on screen siad about library is W5500 configuarion not support Core2.
      M5 Support team please help to update F/W for Core2 can support LAN base as well.
      posted in UIFlow
      J
      jollawat
    • RE: How to use two ENV units with PaHUB (UIFlow)
      @liemph I tried connect and program by UIFlow it but there are some error after run on screen said “please remove ENV hat” when we add PbHUB into list.
      posted in Units
      J
      jollawat
      Hi Guys
      I have some further question, what about M5Stick C + ENV HAT + PbHUB connect together?
      posted in Units
      J
      jollawat
    • PbHUB CH4 and CH5 cannot set to digital read?
      Today I try to connect OP180 via PbHUB that using CH4 and CH5 but cannot be detected, I tried to erase and re-burn firmware by using M5 Fire it's show CH4 and CH5 read value (disconnected all CH) is not over 1000 .
      I checked with schematics seems CH4 and CH5 input is only Analog.
      Kindly confirm me as well before I send this unit to RMA process.
      posted in Units
      J
      jollawat
