I am using C++. I don't see any examples of how to calibrate the unit. From the library, there is not function like set_calibrate(....). What is the proper code to do this? Of course, when the unit is started again, how does the calibration factor reused?
How to calibrate weightI2C unit?
Weight I2c wire connector
Is there any secret in how to unscrew the screws on the orange connector for the wires that go to the load cell? I have tried several screwdrivers and nothing seems to move them. I am afraid of stripping the head. Any suggestions?
RE: I2c failure with MPU6050 component
More information
If I use M5Unified.h and then a begin of M5.begin(), the data is all zeros. If I take out the begin, then the data is correct. There must be something in the M5Unified that is restarting the Wire or taking over the I2C bus.
How can I correct this. It is a show stopper. If I can find a solution, then I will have to discard the M5Stack basic and go to a regular ESP32.
I am using a simple Arduino sketch to get values from the MPU6050 over I2C. The only values I receive are 0. Also, I cannot write to any register. The I2C scanner shows it is connected.
If I use an Arduino Mega2560, the device works correctly.
I have also tried to use a M5Stack MPU6886 and it fails as well.
I am using a M5Stack Basic.
