    2. fei_96
    F
    • Continue chat with fei_96
    • Start new chat with fei_96
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Posts made by fei_96
    • RE: I can't connect to AWS IOT Core service
      Hi ajb2k3,
      Thanks for your response. I can't understand what is "incognito
      profile", Do you refer to AWS cognito?
      I was able to connect my M5Stack basic core using Arduino IDE. So, I
      think that the problem is UiFlow IDE.
      I don't know if AWS IoT function of UiFlow is supported for M5Stack
      basic Core.
      Best regards
      posted in Events
      F
      fei_96
    • I can't connect to AWS IOT Core service
      Hi, I am trying to connect my M5Stack to the AWS service using MQTT protocol. I tried various possible ways and had no good results.
      A similar problem was already discussed in the forum but not resolved.
      It was mentioned that the problem could be the policy associated with the object, in my object I used the following policy:
      Previously I was able to connect the same device by programming it from the arduino IDE. In that case I used the same format for designing the object policy, which would seem to indicate that this is not the problem.
      In the figure there is a simple example, which should send one message per second.
      From the AWS console, in the test tab it is not possible to subscribe with the topic corresponding to the messages sent by the device.
      From the monitoring section in the console it is visualized that the connection between the device and AWS seems to be made.
      Somebody could help me? In order to advance my project, I need to first achieve this communication with the kit.
      posted in Events
      F
      fei_96
