    2. cmisztur
    C
    • Continue chat with cmisztur
    • Start new chat with cmisztur
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Save
    Saving
    cmisztur
    @cmisztur
    0
    Reputation
    11
    1139
    Profile views
    0
    Followers
    0
    Following
    Joined Last Online
    cmisztur Follow
    Posts made by cmisztur
    • RE: live motion tracking with multiple m5stickc in unity [QUESTION]
      @shintobi check out some of the scenes like ping-pong. It’s in a script on a GO.
      posted in PROJECTS
      C
      cmisztur
      @lukasmaximus , below is some code I used on PYCOM hardware and WebBluetooth. I ran into issues when getting characteristic notifications faster than 1/2 sec. Not sure if it was an IDF GATT issue or WebBluetooth or PYCOM implementation. But it did kinda work.
      https://pastebin.com/We2S8JwR
      https://pastebin.com/HDrktkQZ
      https://pastebin.com/s23hUMiD
      https://pastebin.com/WtWr9C2J
      https://pastebin.com/7d9CEyuR
      posted in PROJECTS
      C
      cmisztur
      @ajb2k3 for this use case I would recommend streaming IMU data to InfluxDB. Seems more appropriate for limb tracking.
      posted in PROJECTS
      C
      cmisztur
      @shintobi , just sent you a voucher to our Unity MQTT asset.
      http://unity3dassets.com/demos/wak-mqtt-demo2/index.html
      posted in PROJECTS
      C
      cmisztur
    • RE: StickC - Serial Problems
      @ajb2k3 Tried a different cable, so I'm assuming stick. Why not edit boot.py. It's micropython, as long as I call the M5 libs during the process, everything should work as intended.
      posted in M5 Stick/StickC
      C
      cmisztur
      Got another one from Amazon and this one works just fine. Chalking it up to busted during shipping :).
      C
      cmisztur
      Same story this morning. Last night flashed the Arduino FactoryTest. This morning trying to get this thing connected on Windows, which is where I flashed it last night.
      C
      cmisztur
      Used the cable that came with it, marked M5. I don't know that is the issue. Before I really had a hard time I modified boot.py and noticed I was getting a GURU error, so ESP was stuck in a never ending reboot.
      C
      cmisztur
      Flipped USB-C cable around, now it is showing up in OSX.
      Going to stick ... ha... with Arduino IDE for now.
      C
      cmisztur
      Tried again on PC, came up as 'USB Serial Device'. Installed 'FT4222 Mode 3 Device' driver 2.12.0.0. Got a COM port. Kind of works. Mostly it keeps disconnecting/reconnecting.
      I can no longer see the device on OSX 10.14.6. Nothing pops up in security about CP driver.
      C
      cmisztur
