@Andrzej-Sailing Thank you for Sharing!!! this helped me tremendously!
Posts made by Chris 0
    RE: HardwareSerial ss(2)? UART connection on 16/17 for a GPS Antennaposted in M5stack Grey
    M5 Stack CGM Monitoring for Nightscout data from Dexcomposted in PROJECTS
Re: Call for articles with your product on M5Stack!!
Hi I'm Chris, I'm not a programmer but I work in Tech. I'm the father of a 16 year old Type 1 Diabetic. So I wanted a simple way to display his Blood Sugar with a dedicated device. The M5Stack fit this purpose perfectly.
So thanks to the help from my friends in a bunch of different tech companies, VMWare, Google, Microsoft, Oracle to name a few…
I created the M5 Scout. Here are my design goals:
- Reuse as much of someone else's good tech so that I don’t have to rebuild it, https://github.com/nightscout/cgm-remote-monitor
 - Leverage the most basic programing so I don’t have to learn to code https://flow.m5stack.com/
 - Have the ability to user a cheap product that can display Blood Glucose data all the time (M5Stack)
PS. Also I might build a version 2.0 with blinking Lights, alarms, different Wifis, electric shocks for when his numbers are out of whack… (I just got my M5fire kit this morning)
For now, the buttons beep and you can make the screen brighter or dimmer (for nighttime use)
On screen you can continuously see:-
BG level (Green when in range red when out of range)
Difference with the last BG level
Time since last update was received (for example if the Dexcom CGM is far from Phone)
The Trend Arrow
Screen brightness (but we could remove that…)
All you need is an M5 Stack device
So here is the link to the code on Git Hub:
https://github.com/ctillier-vmware/BLocklyCGMforM5StackHere is the link to the Youtube video I made to explain the process:
https://youtu.be/SqZU-1NvGRs!
