    2. Calvorotas
    C
    • Continue chat with Calvorotas
    • Start new chat with Calvorotas
    • Flag Profile
    • Profile
    • Following
    • Followers
    • Blocks
    • Topics
    • Posts
    • Best
    Save
    Saving
    Calvorotas
    @Calvorotas
    Reputation
    1433
    Profile views
    0
    Followers
    0
    Following
    Joined Last Online
    Location Spain
    Calvorotas Follow
    Posts made by Calvorotas
    • RE: M5stack Grey + M5GO bottom
      Hi,
      Issue solved.
      The problem was in the 15x2 PIN BUS of the M5Stack core.
      It was been necessary to adjust all pins.
      Now, it is works fine.
      Thanks.
      posted in M5stack Grey
      C
      Calvorotas
      @world101
      Hi,
      Thanks for your help.
      V1.1.2 firmare: OK
      M3x16 screws: OK
      GO bottom firmly fastened with the Grey core: OK
      If I press the Grey core and the bottom, the RGB bar works. But not the microphone.
      If I change the force direction, then the microphone works, but not the RGB bar.
      When I stop the force, then the bottom doesn't work.
      There is a electric problem inside GO bottom.
      I will have to speak with M5Stack technical support.
      Thanks again.
      C
      Calvorotas
    • M5stack Grey + M5GO bottom
      Hi,
      I bought a M5GO bottom for my M5stack Grey. Because, I want to use the M5stack with Lego.
      With IUFlow, I can use the MPU9250. Perfect!
      But the microphone, the RGB bar, or B and C ports, do not work.
      Is possible use this elements of the M5GO bottom with a M5stack Grey?
      Thanks in advance.
      C
      Calvorotas
