Webburner & Plus2
Hello.
Why webburner not containt M5 Stick Plus?I programmed my SP2 (Stick Plus 2 :-)) by Arduino (ok),
and I have return to programming it by M5 Flow, BUT:- M5Flow connect to SP2
- M5Flow webburner not have Plus2, programming Plus2 as AtomS3
- M5 Flow can't Run or Download program to SP2 :-(
This is not my first M5, I have several different ones - Core, Atom, AtomS3, AtomS3U...
but only with Plus2 i have problem.And esptools not work on my computer :-( say: "Acces denied..."
Regards
Kajetan -
You need to check your computer setup as something is missing or not accessible. Also web burner only works with chrome browser
Thanks for the hint,
Unfortunately - regardless of the browser (Chrome,Edge) and computer it ends up as in the screen shot. But Arduino programs it fine, uploads and works.So I suspect that something is wrong with the uploaded BIOS, because in the list there is no M%Stick Plus2 (or any other stick) and it prompts me with AtomS3. Maybe I have something not loaded in M5Flow? I don't understand it.
Regards,
K. -
go to m5stack and download separate M5Burner v3 so you have full list of devices and firmwares covered
powodzenia
