    AtomDTU NB-IoT
    Atom
    25.3k
    • felmueF
      felmue
      Hello @Felix22
      I am happy to hear you got it working.
      Thanks
      Felix
      Code examples
      • F
        Felix22
        now, i have a new problem.
        The mqtt broker test.mosquitto.test is working with my Blockly but my own Broker on my Server at home in a Docker container is not available from AtomDTU. But with a Internet Test Tool, it is working ( https://testclient-cloud.mqtt.cool/ )
        I see no difference...
        The orange part is working and the tree other is not working
        • Domainname
        • IP-Address
        • Dyndns
          not working...
          test.mosquitto.org is working fine.
        • felmueF
          felmue
          Hello @Felix22
          hmm, that's a tricky one. Now that your modem gets an IP address; have you tried the official MQTT blocks?
          Thanks
          Felix
          Code examples
          • F
            Felix22
            you mean the blocks at "Fortgeschritten" / MQTT ?
            over there it connects over Wlan/Wifi...
            Is there a MQTT-Block how i can say the RX and TX pin ?
            • felmueF
              felmue
              Hello @Felix22
              no, I meant in UIFlow1 with M5Atom selected. Then it's under Base - DTU - NB-IoT - MQTT. There even is an MQTT example.
              Thanks
              Felix
              Code examples
              • F
                Felix22
                this hangs by the "Init NB-IoT DTU" Blockly if you have not Load the Unit NB-IoT.
                But with the NB-IoT-Unit and the correct RX/TX Pin's it works fine.
                Do you also use the Atom DTU NB-IoT ?
                • felmueF
                  felmue
                  Hello @Felix22
                  not exactly; I use an C-Back NB-loT Global version (SIM7020G) which I connected to an M5Atom the same way it is connected in the AtomDTU NB-IoT.
                  And no, I do not need to add the NB-IoT unit for the Init NB-IoT DTU block to work.
                  Thanks
                  Felix
                  Code examples
                  • felmueF
                    felmue
                    Hello @Felix22
                    I have successfully connected, subscribed and published to the following free MQTT brokers: mqtt.m5stack.com, broker.mqtt.cool, test.mosquitto.org, broker.hivemq.com, broker.emqx.io, and public.mqttserver.eu using below UIFlow:
                    Thanks
                    Felix
                    Code examples
                    • F
                      Felix22
                      Do you have a list with the Status Codes ?
                      Signal Qualität: 16
                      MQTT-Connection: 0
                      Network-Registration: 7
                      GPRS network registration
                      • felmueF
                        felmue
                        Hello @Felix22
                        sure, here you are:
                        • Signal Quality: 17
                        • MQTT-Connection: 0
                        • Network Registration: 7
                        • GPRS Network Registration: 5
                        and when connected to MQTT broker
                        • MQTT-Connection: 1
                        Thanks
                        Felix
                        Code examples
                        • F
                          Felix22
                          Hello Felix
                          By the error code I meant what the individual numbers mean.
                          Each code 0 to x
                          Do you have a code list ?
                          Greeting
                          Felix
                          • felmueF
                            felmue
                            Hello @Felix22
                            no, sorry, I don't have such a list. But if the error code is from an AT command you should be able to find its meaning from the AT command document linked on the product page.
                            Thanks
                            Felix
                            Code examples
