    SIM7080 module, power down and power up
    3 Posts 2 Posters 3.2k Views
    • H Offline
      HappyUser
      Does anyone know how I can power down and power up the sim7080 module.
      AT+CPOWD is to power down, but how to wake up?
      Thanks
      • felmueF Offline
        felmue
        Hello @HappyUser
        you are using the IoT BASE CatM base, correct?
        If yes, GPIO12 is the PWR_KEY. Sending a 500 ms pulse Low-High-Low should power up the modem.
        If no, then I think you are out of luck as the PWR_KEY pin of the modem is tied to the STATUS pin of the modem to autostart the modem when power is applied.
        Thanks
        Felix
        Code examples
        H 1 Reply Last reply Reply Quote 0
        • H Offline
          HappyUser @felmue
          @felmue Thank you. Unfortunately currently I am using the other SIM7060 module. Well, I could power it down with an optocoupler or something like that. Maybe a good idea in future modules to incorporate the deep sleep logic.
