TypeError: 'str' object isn't callable
I need help with my web page hosting code.
Can someone point out what I'm missing?
from m5stack import *
from m5ui import *
from uiflow import *
import networksetScreenColor(0x111111)
label0 = M5TextBox(0, 62, "label0", lcd.FONT_Default, 0xFFFFFF, rotate=0)
label1 = M5TextBox(0, 89, "label1", lcd.FONT_Default, 0xFFFFFF, rotate=0)import gc wlan = network.WLAN(network.AP_IF) wlan.active(True) wlan.config(essid='ESP_test', password='123456') if (wlan.isconnected()) == False: label0.setText('No connection to Access Point') else: label0.setText('Connected to Access Point') label1.setText(str(wlan.ifconfig())) #False resaults when run and not downloaded. html_page = '''<!DOCTYPE HTML> <html> <head> <meta name=βViewportβ content=βwidth=device-width, initial-scale=1β </head> <body> <center><h1>Yun Cloud Sensor Suite. </h1></center> <center><p>Temperature is <strong>βββ + str(t) + βββ C.</strong>.</p></center> <center><p>Pressure is <strong>βββ + str(p) + βββ Pascal.</strong>.</p></center> <center><p>Humidity is <strong>βββ + str(h) + βββ Percent.</strong>.</p></center> </body> </html> ''' html_page import socket s = socket.socket(socket.AF_INET, socket.SOCK_STREAM) s.bind(('', 80)) s.listen(5) gc.collect() conn, addr = s.accept() print('Got a connection from %s' % str(addr)) request = conn.recv(1024) request = str(request) print('Content = %s' % request) response = html_page() conn.send('HTTP/1.1 200 OK\n') conn.send('Content-Type: text/html\n') conn.send('Connection: close\n\n') conn.sendall(response) Conn.close() while True: wait_ms(2)Error is as follows
'<!DOCTYPE HTML>\n\t\t\t<html>\n\t\t\t<head>\n\t\t\t\t<meta name=\u201cViewport\u201d content=\u201cwidth=device-width, initial-scale=1\u201d\n\t\t\t\t</head>\n\t\t\t<body>\n\t\t\t\t<center><h1>Yun Cloud Sensor Suite. </h1></center>\n\t\t\t\t<center><p>Temperature is <strong>\u201d\u201d\u201d + str(t) + \u201c\u201d\u201d C.</strong>.</p></center>\n\t\t\t\t<center><p>Pressure is <strong>\u201d\u201d\u201d + str(p) + \u201c\u201d\u201d Pascal.</strong>.</p></center>\n\t\t\t\t<center><p>Humidity is <strong>\u201d\u201d\u201d + str(h) + \u201c\u201d\u201d Percent.</strong>.</p></center>\n\t\t\t</body>\n\t\t\t</html>\n' Got a connection from ('192.168.4.2', 49311) Content = b'GET / HTTP/1.1\r\nHost: 192.168.4.1\r\nConnection: keep-alive\r\nCache-Control: max-age=0\r\nUpgrade-Insecure-Requests: 1\r\nUser-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36\r\nAccept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9\r\nAccept-Encoding: gzip, deflate\r\nAccept-Language: en-GB,en-US;q=0.9,en;q=0.8\r\n\r\n' Traceback (most recent call last): File "<stdin>", line 42, in <module> TypeError: 'str' object isn't callable >>> >>> >>>
With your input, this post could be even better π
