    Save variables permanent for power cycle
    UIFlow
    3.9k
    • M
      mchott
      Is there a way to save a variable value permanent. So after a power cycle I can use this value?
      Currently I have to set the value in the UIflow and flash the AtomMatrix.
      M 1 Reply Last reply Reply Quote 0
      • M
        mchott @mchott
        @mchott I tried several things including EEPROM.
        Is it possible that the EEPROM function on the Atom Matrix simply does not exist? The button B on the side does not exist in UIflow either.
        • felmueF
          felmue
          Hello @mchott
          EEPROM function works for me - see below. However what I found is that reading a value (after storing it) takes a couple of seconds until the new value is read. Second I found EEPROM read key ... to int doesn't work for me.
          AFAIK there is no button B on M5Atom (lite or Matrix). The button on the side is a hardwired reset button.
          Thanks
          Felix
          Code examples
          • M
            mchott @felmue
            @felmue Super!!!
            The EEPROM seem to have some problems with integer values and fast timing.
            I store my integer now as string and wait until read is finished and it works.
